datatool alarm had it :(
bought my falco with a Datatool system 3 fitted, now it won't arm/disarm, whole range of symptoms, the worst of which is that the bike is immobilised.........which means going in. Wrote to datatool, but they just advised removal so I'm going to have to have a go - anyone got any pointers for someone fairly clueless and armed only with a multimeter? Which I don't really know how to use?
- anzacinexile
Bluddy hate alarms with a vengeance.
I removed mine by simply tracing each wire to where it joined the loom and by referencing it to the wiring diagram figured out what that wire did.
Isn't as scary as it sounds when you consider, one wire power, one wire earth, one wire indicators so the remaining 2 is where it breaks into the ignition circuit. you might be lucky and whoever fitted it might have used the factory fitted socket.
BEFORE you cut any wires, mark each side of the cut with a label with a number so if it all goes tits up, you know which wire joined up to the other half (although with a busted alarm, that wont get you anywhere)
My Meta alarm has been great (bought 2nd hand from ebay and fitted it myself)
I've heard so many horror stories from those with datatools that I'd never let one near a bike of mine ...
Maybe the perception exaggerates the truth but I'm not for taking the chance.
Hope you get things sorted.
Nope - they're not all bad.mangocrazy wrote:Fixed it for ya...D-Rider wrote:I've heard so many horror stories from those with alarms that I'd never let one near a bike of mine ...
Extremely happy with mine
- anzacinexile
WeelllD-Rider wrote: Nope - they're not all bad.
Went through 3 on the Falco (different makes) wifey went through 2 (Meta's) the last in the Mont Blanc Tunnel, my work Fazer chewed hers and her predecessor shat hers (Datatool)
........so - you can see why I hate them with a vengeance. No way those turds from the Devils bottom are going anywhere near my bikes thank you
- anzacinexile
- Samray
- Double World Champion
I like them too.anzacinexile wrote:I know what you mean. Having junked all my alarms I invested in a Xena alarmed disc lock for peace of mind in rough places. Gawd only knows how something so small can make so much noisebigun wrote:I do miss the peace of mind of the alarm siren tho.
- furygan man
...Even i managed that...hated the alarm and it drained the battery. Traced each wire back, took about 15 minsanzacinexile wrote:Bluddy hate alarms with a vengeance.
