Rear shocks: Availability?
Posted: Sat Nov 12, 2011 4:42 pm
by irich
Quick question to the learned:
Apart from sourcing a used shock from the right year Mille etc, is there a currently available direct replacement shock from Ohlins or WP that will fit the Falco?
The Ohlins AP941 46PRC appears to have been discontinued?
Edit. Search helps
https://www.ridersite.com/viewtopic.ph ... ight=shock
Posted: Sat Nov 12, 2011 4:52 pm
i think - and is only think
maxton do one
there is some old stock wp items knocking about - wpp8848 iirc - please check that though
wilburs - i believe....
Posted: Sat Nov 12, 2011 5:03 pm
by irich
Thanks ALS
The Nitrons look like good value, anybody used them here?
http://nitron.co.uk/nitron09/index.php? ... e9f4fd2bf0
Pretty basic unit in respect of adjustment but they make good gear from what I know.
Edit they also do a fully adjustable unit:
http://nitron.co.uk/nitron09/images/ima ... _black.jpg
Have to do something about that colour though.
Posted: Sat Nov 12, 2011 5:51 pm
looking at the prices, you can see why many of us go for obtaining a mille item and refurbing it.....
Posted: Sun Nov 13, 2011 9:32 am
irich wrote:Thanks ALS
I got the Nitron "track" version (mid-range) and have been extremely happy with it, can't say I've done much with it as it was set-up when I got it (and a check with Griff didn't show any problems with setup)
Didn't pay that much though! Got mine (IIRC) for about £460, try searching some of the dealers (Moore Speed was mine), they order at a discount but it arrives straight from the factory
Posted: Sun Nov 13, 2011 12:35 pm
by irich
Aladinsaneuk wrote:looking at the prices, you can see why many of us go for obtaining a mille item and refurbing it.....
Yep, looking around, a new shock can cost more than third of what the bike cost me :smt101
Being a cheap Yorkshireman by birth I'm always keen on the £3-75 option.
If you have a line on a used Ohlins replacement I'm all ears.
Posted: Sun Nov 13, 2011 12:36 pm
by irich
Firestarter wrote: I got the Nitron "track" version (mid-range) and have been extremely happy with it, can't say I've done much with it as it was set-up when I got it (and a check with Griff didn't show any problems with setup)
Thanks Dude.
Posted: Mon Nov 14, 2011 8:23 am
by robbier6
Maybe a hagon shock for the early mille will fit? got one on my KR1S track bike and its fabulous, and under £300.
Posted: Mon Nov 14, 2011 9:30 am
i note the hagon shock fits 1998 to 2004 - and bearing in mind our knowledge of the different linkages this gives me some doubts.... how can one shock replace three different ones with regard to linkages?
also, at 300 quid - even with a 2 year warrenty, i am not that convinced of the value - a personal view i hasten to point out
Posted: Mon Nov 14, 2011 10:12 am
They do one for the Falco - so no point in looking at the Mille ones with associated linkage complications.
I have no experience of Hagon but I recall the previous discussions have suggested them to be a bit more down the budget end and for the same sort of cash you can get a second hand Ohlins and have it serviced.
Posted: Mon Nov 14, 2011 10:26 am
by robbier6
Oh i agree with the second hand Ohlins point D.
but some people do prefer the peace of mind of brand new, and whilst i agree they don't have the pose value of Ohlins i found it worked very well for me on the track.
Alad, no having looked or his website site i concur with you, how does 1 shock fit multiple linkages.
Posted: Mon Nov 14, 2011 10:43 am
Yes - I'm not arguing - as I said, I've no experience of the Hagon shocks so cannot objectively compare.
Posted: Mon Nov 14, 2011 10:49 am
by robbier6
D, i know, as you say everything is objective.
Posted: Mon Nov 14, 2011 5:57 pm
by MartDude
Comments on AF1 Futura forum re Hagon shock were on the lines of - ok, but not a significant improvement. But, IIRC, the Futura Sachs shock isn't quite as dismal as the Falco one is said to be.
Posted: Mon Nov 14, 2011 7:11 pm
One thing I would say about a secondhand Ohlins - they can be refurbished to indistinguishable from new for not a lot of money. So the fact that new ones aren't available shouldn't really be a concern. I've seen inside a number of Ohlins shocks and the component quality is absolutely top-notch. They are also fully rebuildable and spares should never be a problem.
Given the choice between spending £250 on a secondhand Ohlins and the same amount on a new Hagon, I wouldn't hesitate. Ohlins every time...
