New shock to buy!
Firestarter
Twisted Firestarter
New shock to buy!
#1 Post by Firestarter » Sun Mar 25, 2007 12:46 pm
Right, having just off-loaded that dodgy white-spring shock (just kidding Falken!), I'm now in a position to buy something else.
Wish I could say money is no object, but I'm budgeting somewhere around £500/£550, which I think keeps me below Matris/Maxton type prices.
Very tempted by the Nitron Track shock (preload/rebound/compression) as they've come recommended by a friend, but I've seen a Falco-specific Ohlins for about £420 (a lot less than the Nitron), but I don't think it "looks" as good. I've also seen Technoflex going reasonable as well...
So, knowing how good you are at using other's credit cards, I'm looking for suggestions. Any taken (except the suggestion where I buy you a shock :smt018 )
Falco9
#2 Post by Falco9 » Sun Mar 25, 2007 7:55 pm
Personally I'd leave the "looks" for other areas of the bike. my personal choice would be summed up in one word
Ohlins!
Enough said
F9 :smt006
Re: New shock to buy!
#3 Post by Gio » Sun Mar 25, 2007 8:12 pm
Firestarter wrote:Right, having just off-loaded that dodgy white-spring shock (just kidding Falken!), I'm now in a position to buy something else.
Maxton's are about £480, I'd have thought that was in your budget, even if you have to add vat its only about £560
#4 Post by D-Rider » Sun Mar 25, 2007 8:34 pm
Be aware that if you go for the Falco Ohlins, you will not have ride height adjustment and you will not be able to fit a mille swinger (should you ever want to) - the reservoir fouls.
I'd go the Mille Ohlins route ..... oh, I did ... :smt003 :smt003
EDIT:
Have since found out that the Falco Ohlins being incompatible with the Mille swinger is a myth .... have seen pictures to prove it does fit!
Firestarter
Twisted Firestarter
#5 Post by Firestarter » Sun Mar 25, 2007 8:36 pm
Having seen Paddy's Maxton today, it looked damn good :smt007 and he's obviously well chuffed with it, and if it's within the price bracket I think that might well be a goer. Phone call in order tomorrow...
F9, thanks, but I'm seeing Ohlins as the easy (and obvious) option. I'm sure I would (might well yet be) very happy with Ohlins, but thought I'd give something else a go first. I take it you like yours, then? Don't fancy swapping it out before you sell it to some unsuspecting individual? :smt005
#6 Post by Gio » Sun Mar 25, 2007 8:51 pm
Firestarter wrote:Having seen Paddy's Maxton today, it looked damn good :smt007 and he's obviously well chuffed with it, and if it's within the price bracket I think that might well be a goer. Phone call in order tomorrow...
I'm watching you :smt018 :smt003
BTW if you like a really nice suspension unit then you should go to this place http://www.setupengineering.co.uk/index2.php.
Firestarter
Twisted Firestarter
#7 Post by Firestarter » Mon Mar 26, 2007 8:20 am
Setup Engineering wrote:JCW Shock
The JCW shock is the first all aluminium unit with 'pure' separable high and low speed adjustable compression damping. It runs 20° C cooler than the latest model OEM alloy-bodied shock and, when fully sprung, weighs between 1 and 1.5 kg less than the same*. Every JCW shock is built with a shim stack, spring and other trick componentry bespoke to rider specification.
Throughout its research and development period the JCW shock was part responsible for winning:
o World endurance racing championship back to back for S.E.R.T - Suzuki Racing Team (France) - in 2002, '03 & '04;
o British Powerbike championships with Jamie Hitter & Black Widow team in 2001 & '02.
It is important to note that throughout the testing period bikes that ran a JCW unit consistently suffered less from tyre wear than those that did not. As observed in Parc Fermé.
To find out more about the JCW Shock please feel free to speak to James directly; his contact details are displayed on the CONTACT/FIND US page found elsewhere on this site.
JCW Shock from £998.00 + VAT
Impressive, but double my budget! :smt119
#8 Post by Kwackerz » Mon Mar 26, 2007 4:41 pm
Theyre also the mutts nuts for setting up standard suspension. Well worth the dosh.
James is a genius.
Firestarter
Twisted Firestarter
#9 Post by Firestarter » Mon Mar 26, 2007 6:00 pm
Well, I've done it. Fancied the Maxton, but when the Nitron (all in, VAT & del.) came back less than the Maxton pre-VAT, that sold it. Plus it does look good :smt007.
Just need to decide how to lift the back end now :smt018
#10 Post by Gio » Mon Mar 26, 2007 6:33 pm
Kwackerz wrote:Theyre also the mutts nuts for setting up standard suspension. Well worth the dosh.
James is a genius.
Don't I know it, he transformed the blackbird :smt003
Thumper
#11 Post by Thumper » Mon Mar 26, 2007 10:53 pm
A few of the first falco owners swore by this company, they produce a top quality shock at a very reasonable price to order.
http://www.technoflex.be/eindex.php
Always expect the unexpected
Firestarter
Twisted Firestarter
#12 Post by Firestarter » Mon Apr 02, 2007 1:02 pm
Right, the new shock should be here this week, and rather than fork out for an Abba (or similar) stand, I'm going to do the "rod through the pivot" method. Has anyone else on here done this, in which case what size of rod did you use? Would a 5mm stell rod do the job?
Of course, if anyone has got an Abba stand that they'd like to lend me, I wouldn't say no :smt003
Gtrain
#13 Post by Gtrain » Mon Apr 02, 2007 1:06 pm
when I changed my rear shock I strung up the back of the bike from the rafters in the garage, looked bloody strange but it did the trick
The problem with common sense is, its not very common
Falken
#14 Post by Falken » Mon Apr 02, 2007 2:07 pm
:smt001
Thanks again for the (dodgy) white spring shok FS.
Had it fitted this morning and set up.
Can't believe the difference.
Adventure before Dementia.
Firestarter
Twisted Firestarter
#15 Post by Firestarter » Mon Apr 02, 2007 4:48 pm
Falken wrote::smt001
Glad it's OK for you, I was concerned cos I really didn't know what it was going to work like. We'll have to get together when I've fitted mine and compare notes :smt003
