Falco bleed nipple size
Posted: Sat Oct 22, 2011 5:17 pm
by keithy
Hi changing my lines looking at auto bleed nipples on the bay size 8mm x 1.25 will these fit the brembo calipers ? thinking of getting them 3 for the front lines, 1 for the clutch and 1 for the rear only £12.99 worth it if they work.
Thanks in advance Keith
Posted: Sat Oct 22, 2011 5:58 pm
Tbh, follow the bleeding guide in the aprilia tech section
You will not need those then.....
Posted: Sat Oct 22, 2011 7:27 pm
by Willopotomas
The only auto-bleed system I've used that works is the Gunsons Easibleed kit. Other one man operation valves don't seem to work very well. You're better off doing it the good old fashioned way. :smt002
