Oil ..... I hadn't realised .....
#1 Post by D-Rider » Wed Aug 31, 2011 10:48 pm
In the great debate about oil, Falcos and clutch slip, I had gathered that the early Falcos often didn't fare well on fully-synth oil though later ones did fine on the stuff. Indeed, I've run mine on fully-synth.
With Aprilia's bulletin recommending that if all else fails in the quest to stop clutch slip, people may use a 10-40 semi-synth, I'd just assumed that the recommended 15-50 oils (IP Extra Raid 4 and Agip TEC 4T) were fully-synth.
I think many other people may have done the same.
Well I've just done some digging as I'm about to order oil to service my bike and I've discovered that these recommended oils are actually semi-synth.
So, it would seem that although later Falcos can run fine on fully synth oil, Aprilia has actually only recommended semi synth oils for them.
.... that's a bit of an eye-opener for me.
#2 Post by Aladinsaneuk » Wed Aug 31, 2011 10:54 pm
often happens with the riders of the slower colours....
and yes, pre 2002 falcos. its semi synth only - IN MY OPINION
#3 Post by HowardQ » Wed Aug 31, 2011 11:15 pm
Exactly !!
#4 Post by D-Rider » Wed Aug 31, 2011 11:58 pm
HowardQ wrote:Exactly !!
That's not my point .... we all know that .....
What I was getting at is this:
I think that the general assumption had been that the oils that Aprilia recommended were fully synth but they gave dispensation to the riders of the old heaps to use 10-40 semi synth to stop their clutches from slipping.
At least, that was what I had previously believed.
Further digging has revealed that the recommended 15-50 oils are also semi synth (not fully synth)
There again, maybe it was just me who had this misunderstanding.
:smt053
#5 Post by blinkey501 » Thu Sep 01, 2011 4:19 am
silkoline 15/50 semi synthetic in mine , though it is 2002
#6 Post by Aladinsaneuk » Thu Sep 01, 2011 5:46 am
lol
no andy, i have only ever run semi synth in mine - and the owners handbook also says this - i think the use of full synth came later.... wether or not is was done by aprilia or some one thinking it was a good idea....
anzacinexile
#7 Post by anzacinexile » Thu Sep 01, 2011 7:23 am
From my perspective, full synth is puss from the Devils bottom :smt011
#8 Post by D-Rider » Thu Sep 01, 2011 8:09 am
Full synth has been fine in mine - but I'll save a bit of money now that I see Aprilia was not recommending fully synth and go for the semi.
#9 Post by mangocrazy » Thu Sep 01, 2011 7:57 pm
Pretty much any good quality 15-50w semi-synth should be perfect for any Falco. I use Motul 5100 15-50w and it's great (but then so are Silkolene, Putoline, Catrol, Agip etc. etc)
The only stuff I wouldn't touch with a bargepole is Rock Oil.
#10 Post by D-Rider » Thu Sep 01, 2011 8:07 pm
mangocrazy wrote:Pretty much any good quality 15-50w semi-synth should be perfect for any Falco. I use Motul 5100 15-50w and it's great (but then so are Silkolene, Putoline, Catrol, Agip etc. etc)
..... though Castrol don't do a 15-50. They would have been my first choice as my Dad worked for their research labs - and I worked there myself (building engines for engine test one summer while I was at Uni). I know they do a pretty thorough job there .... well, they did in the early '80s and I hope they still do.
.... my Grandad worked for Shell too.
I've gone for Silkolene from our friends at Opie Oils
#11 Post by Aladinsaneuk » Thu Sep 01, 2011 8:26 pm
Try 10/40 semi - a lot more choice then....
anzacinexile
#12 Post by anzacinexile » Thu Sep 01, 2011 8:40 pm
Aladinsaneuk wrote:Try 10/40 semi - a lot more choice then....
Thats what I run :smt023
Clutch drag - whats that then :smt017
#13 Post by D-Rider » Thu Sep 01, 2011 10:06 pm
Nah - I'd sooner stick with what Aprilia chose to recommend rather than what they fell back on for the old nails with slippy clutches.
.... and I don't need a wider choice having found what I need :smt002
(yeah I know 10-40 should be OK but I'd prefer to stick with the 15-50 ..... I have, at least, moved away from fully synth this time)
Falco9
#14 Post by Falco9 » Fri Sep 02, 2011 10:25 am
mangocrazy wrote: The only stuff I wouldn't touch with a bargepole is Rock Oil.
Interesting comment as I use Rock Oil in both my bikes and it does the job just fine. Good quality oil at the right price. Why wouldn't you use it? :smt017 It meets and exceeds all the standards required for motorcycles and is recommended by Kawasaki & Suzuki not to mention BMW & Porche. And Rock Oil's racing pedigree is long and successful, I know BSB racers and motorcrossers who swear by it
F9 :smt006
#15 Post by HowardQ » Fri Sep 02, 2011 12:32 pm
My response was really an "exactly" reply to the second line about the semi synth only for my bike which is 2001, and the usual tongue in cheek comment about the first line about fastest colours.
As I have mentioned before the local Aprilia dealer put Putoline fully synth in mine at the 10K service, and the clutch slipped goiong home and was much worse that weekend.
Talked to the dealer asked why they had used it and the answer was that they always used it full stop, no problem. I suggested that I knew other people who suggested it should never be used, but their reply was a simple try changing it if you want. Otherwise it will cost you £XXX for a new clutch. Had just paid well over £550 quid for 10K service plus chain and sprockets so didn't have the money for the clutch.
Stopped at Halfords on the way home, got a can of Castrol semi synth, and changed the oil and filter. The clutch slip instantly went away and, 22k miles later, the original clutch is still fine, still using Castrol.
It works for me mate!
