Falco9
#1
by Falco9 » Wed Apr 20, 2011 1:36 pm
I'd like to purchase one of these as I'm pretty sure my sidestand switch is kaput. But even though Ed @ AF1 has offered me a $20 uninsured postage option its still well over double the cost of actual item
http://www.af1racing.com/store/Scripts/ ... oduct=3173
So the question is...would a plug like this be difficult to replicate?
Or a better question as I don't want to take business away from Ed is... does anyone else want to purchase one of these plugs?
Ed has a $40 fully insured UK postage option and that covers up to 2kg in weight so a few more being ordered on one postage charge would make these items much more cost effective to buy here in the UK. The value of plugs is pretty low so hopefully it wont attract any import duty. So I wondered if three or four of you may be interested, I'd buy them and then send them out to each of you from here
Let me know if you are interested
F9
#2
by Kwackerz » Wed Apr 20, 2011 1:45 pm
Just a bit of wire in a loop with the connectors hidden inside a connector block
Probably make that from stuff at maplins for under a quid?
Falco9
#3
by Falco9 » Wed Apr 20, 2011 2:20 pm
Kwackerz wrote:Just a bit of wire in a loop with the connectors hidden inside a connector block
I thought that would probably be the case!
Anyone fancy making a "UK" version then??
F9
#4
by Kwackerz » Wed Apr 20, 2011 2:34 pm
http://www.apriliaforum.com/forums/show ... hp?t=18415
shows how to bypass the switch but keep the indicator light functioning.
Making a copy of the bypass loop would be really easy. If I had a SL or an RSV then I would, but haven't so I shant.
Falco9
#5
by Falco9 » Wed Apr 20, 2011 2:49 pm
Kwackerz wrote: Making a copy of the bypass loop would be really easy. If I had a SL or an RSV then I would, but haven't so I shant.
Not the "caring for others" thought process I'd normally expect from you Tim
I'm hoping that a trip to Maplins with the original connector may result in someone there showing me how to do it. I want to remove the switch from the bike all together, so a replacement plug is the perfect solution for me.
Funnily enough reading that thread did highlight the cutting out problems I've been having with my Falco, although it doesn't account the dash board gremlins
F9
#6
by Kwackerz » Wed Apr 20, 2011 5:23 pm
A lack of an original connector was all that was amiss, or i wouldve
bigun
- AP RS Legend
- Location: South Witham (nr Stamford Lincs) - exiled Geordie!
#7
by bigun » Wed Apr 20, 2011 7:59 pm
Hey up Rich,
a lad on Aprilia Performance site has a sidestand switch for sale if its any use? £15. Seems spot on, I'm getting a headlight from him and all been good.
http://apriliaperformance.myfastforum.o ... 895-20.php
Hope it helps!
Paul
Bigun
#8
by Falcopops » Thu Apr 21, 2011 12:14 am
Hey Rich,
Keep your wallet in your pocket mate.
I'm pretty sure I've got the bit's lurking about in my garage. I've got a bit of electrical work to do and I can knock one of these off in no time flat.
Send me your address and I'll chuck it in the post, gratis.
Let me know
Falco9
#9
by Falco9 » Thu Apr 21, 2011 9:47 am
Cheers Paul,
I'm not actually sure there is anything wrong with the switch other than the fact it may not like being sat on the engine! hence why I'd like to remove it altogether and eliminate any current / future cut out problems. But cheers for the heads up mate
Falcopops.
If you can knock me up a plug I'd be delighted mate, but not free gratis (although I do appreciate the offer) I'll send over some folding via PayPal or I could make a donation to a charity of your choice with pleasure.
Many Thanks and I'll drop you a PM
F9
