Falconihlist
#1
by Falconihlist » Wed Apr 13, 2011 4:22 pm
anyone know where I can get some link pipes made up for a reasonable price? I did use search, but the word "exhaust" happens to pick up on a certain signature
As an aside, is there any specific reason both the mid pipes meet up, or would there be benefits in having totally seperate pipes?
Black is fastest!
#2
by Aladinsaneuk » Wed Apr 13, 2011 4:40 pm
Well .... Worms in a can....
I think fuel have done some work for Andy in the past.....
Unless you can find a set of falco High mount cans, I would consider the Mille full system - more options then
With regard to the siamesed mid section .... Not much you can do with the falco pipes.... The Mille mid section allows for balance pipes....
Falconihlist
#3
by Falconihlist » Wed Apr 13, 2011 5:46 pm
I do like the system, especially the one you have set up on yours, but I think I may run into problems with the swingarm clearance. I am going to have to get the tape measure out on that. I do like the look of a twin setup though
Black is fastest!
#4
by D-Rider » Wed Apr 13, 2011 7:10 pm
No - I bought my can from them (at the NEC a few years back). I asked them to supply both high and standard mount link pipes so that I could have the choice but both of these were their standard Mille items (for my Mille 2:1 exhaust)
Falconihlist
#5
by Falconihlist » Wed Apr 13, 2011 7:26 pm
Andy, have you got two of the same link pipes, or are they different for each side? I've just measured the clearances for fitting an 04 swingarm, and it is going to be too tight to have a pipe crossing under the seat.
Black is fastest!
#6
by D-Rider » Wed Apr 13, 2011 7:37 pm
Falconihlist wrote:Andy, have you got two of the same link pipes, or are they different for each side? I've just measured the clearances for fitting an 04 swingarm, and it is going to be too tight to have a pipe crossing under the seat.
My exhausts are different on each side ....... on the right I have an exhaust ..... on the left I don't .....
Reasons I went for a 2:1 exhaust:
- I like the look
I like the fact that it doesn't hide the nice Mille swingarm on the left side
Reduced cost of cans (I only need to buy 1)
Better choice of cans (everyone makes them for the Mille
I guess it weighs a bit less - allowing me greater pie consumption
Falconihlist
#7
by Falconihlist » Wed Apr 13, 2011 7:54 pm
- I like the look
That's why I like this forum, no conformity to anything in particular, and practical answers
Right then, time to inform SWMBO that the living room is being turned into a garage next month and that the pets are on the cheap stuff for the next month.
Black is fastest!
#8
by Aladinsaneuk » Wed Apr 13, 2011 9:09 pm
but for those of us with a svelte figure
a 2 into 1 into 2 is a better system... IMHO
the mille option does give more choice in aftermarket cans
and it really freaks mille owners out when you start measuring their donor bikes...
#10
by MartDude » Thu Apr 14, 2011 9:11 pm
Aladinsaneuk wrote:but for those of us with a svelte figure
What would you know about that?
#11
by Aladinsaneuk » Thu Apr 14, 2011 9:25 pm
not as much as you after the shit has been ripped out....
#12
by D-Rider » Thu Apr 14, 2011 9:52 pm
MartDude wrote:Aladinsaneuk wrote:but for those of us with a svelte figure
Jadaris wrote:Aladinsaneuk wrote:
Fatty will not make it as her leathers do not fit.... Apparently because her arse has got fat...
Fatty!!!! You wait till I see you later, as I recall your belly got prodded recently with the question "What's in there Daddy?"
Out of the mouths of babes .......
(and no Pete - we weren't talking about that kind of babes .....)
