Bike stand
wayno
Bike stand
#1 Post by wayno » Mon Mar 28, 2011 8:32 am
Just managed to pick myself up a NWS Ulti-pro bike stand on ebay for under £30 :smt001
Anyone not knowing these, they're like an abba stand on steroids (and without the money making scam of having to change the pins for each model)
Got no discussions points about it, just wanted to brag :smt003
http://www.n-w-s.com/nws/stands/
#2 Post by Nooj » Mon Mar 28, 2011 11:48 am
Interesting, how do the universal pins work?
wayno
#3 Post by wayno » Mon Mar 28, 2011 1:41 pm
They just use a tapered pin instead of whatever it is that's bike specific, the pins fit inside the swingarm pivot bolt.
The ABBA stands look a bit puny for me (especially for the £80 or whatever they cost), these look good and strong.
I'd never seen one until my mate bought one for his daytona 955.
I'll pop up some pics of it holding the bike up once it arrives.
Falconihlist
#4 Post by Falconihlist » Mon Mar 28, 2011 1:49 pm
One of the guys has that stand at work, and he has a booking sheet filled for the next couple of weeks as he lends it out. Nice and simple to use, and stores away quite compact too:)
Black is fastest!
wayno
#5 Post by wayno » Mon Mar 28, 2011 2:16 pm
I love them, I used my mates on my old FZR a couple of times, solid as a rock, don't think I've had the Falco up on it (although my memory isn't great).
I've had it on auto search on fleecebay for about 3 months been waiting for one to come up, this is the first one that came up and luckily I got it for a steal.
#6 Post by D-Rider » Mon Mar 28, 2011 5:34 pm
I have one of these (as I have posted on many occasions)
Essentially like the abba but the ulti-pro is better constructed.
It doesnt have the attachments that the Abba has (as an option) to let you remove the swingarm.
#7 Post by Willopotomas » Mon Mar 28, 2011 5:38 pm
For those with an abba stand (Or the ulti-pro for that matter) I can, and have made tapered inserts. I'm in the throws of making some for Paul, so if anyone else wants some making, I'll knock a few out all at once. :smt001
#8 Post by Aladinsaneuk » Mon Mar 28, 2011 6:10 pm
and paul is grateful - i was working on hanna's and craig's falcos and craig rode off with one of the spindles still in the swing arm - I forgot to check!
oh - for the record, Craig was very impressed with the move from a standard blue spring sucks shock to a white spring mille unit.....
#9 Post by Nooj » Mon Mar 28, 2011 6:15 pm
Willopotomas wrote:For those with an abba stand (Or the ulti-pro for that matter) I can, and have made tapered inserts. I'm in the throws of making some for Paul, so if anyone else wants some making, I'll knock a few out all at once. :smt001
Ap-tho-lutally! Put me down for a set!
#10 Post by D-Rider » Mon Mar 28, 2011 8:13 pm
The ulti-pro ones are tapered as standard .... guess those devotees of the swedish-pop-combo-stand will need some to catch up ...........
#11 Post by Willopotomas » Mon Mar 28, 2011 8:29 pm
Mine was free.. So can't grumble.. The inserts were also free, so again, no complaints from me. :smt003
wayno
#12 Post by wayno » Tue Mar 29, 2011 7:12 am
Willopotomas wrote:Mine was free.. So can't grumble.. The inserts were also free, so again, no complaints from me. :smt003
Jammy bugger
#13 Post by HowardQ » Tue Mar 29, 2011 11:58 am
Have owned an NWS Ultipro for years, sadly NWS are no longer around.
It was expensive to buy, (Just over a ton as I remember), but a superbly stable and easy to use stand, that was worth the outlay.
Was hoping to try and get some different pins so I could also use it with the 9R, but not now possible. Found out the standard ones will work with the Kwack anyway even though the hole in the offside pivot is like a big Alen key and is bigger than the Falco. This just makes the stardard tapered pin go in a bit further and the stand is then closer at that side of the bike.
Otherwise works perfectly on both bikes, couldn't do without it now!
Great buy at £30 by they way!!! :smt023
wayno
#14 Post by wayno » Tue Mar 29, 2011 2:28 pm
As far as I know NWS are still trading, the link is at the top of this thread (although I haven't tried calling them)
That's the beauty of the Ulti-pro, that the tapered pins just push in further for bigger holes and less for smaller ones, so it will fit pretty much anything with a hole in the end of the swingarm bolt.
They seem to go for a lot less than the 'dancing queen' ones too on e-bay, my mate who first brought them to my attention got his for £20
back_marker
#15 Post by back_marker » Tue Mar 29, 2011 5:13 pm
I tried calling NWS a couple of years ago to try and buy one of these, and was told I was actually talking to Pyramid Plastics as they have taken over the bodywork side of things when NWS stopped trading.
Ended up buying an ABBA instead in the end.
- Steve McQueen
