lean angle - new stand - bubseywoo
LEEMAN
#1 Post by LEEMAN » Mon Feb 21, 2011 9:16 am
As mentioned previously I have the new Bubseywoo stand.
Fitted it yesterday but the lean angle is just as bad as my previous b*stardised version, i.e: 45deg angle, which also means the bike still has to have a piece of wood added as a prop for the stand.
I have realised now that the problem could be with the mounting plate that attaches stand to lower frame.
Does anyone have a spare OE mounting plate? or know where I can get one?
The stand could be ok though does look a little short in my opinion, also I recognise I may need to adjust the height of the recently fitted white shock to accommodate the new stand.
will try and post a pick of the mounting plate and new stand.
Dave
#2 Post by Aladinsaneuk » Mon Feb 21, 2011 12:25 pm
Send it back and get a refund - then chat with will
dyzio
#3 Post by dyzio » Mon Feb 21, 2011 12:29 pm
Aladinsaneuk wrote:Send it back and get a refund - then chat with will
Who's Will?
#4 Post by furygan man » Mon Feb 21, 2011 12:33 pm
Who's Will?
Oh yes Will...top bloke!
LEEMAN
#5 Post by LEEMAN » Mon Feb 21, 2011 2:17 pm
thanks chaps..........so who is this dude Will?
i still think the mounting plate is at fault
#6 Post by Samray » Mon Feb 21, 2011 2:43 pm
LEEMAN wrote:thanks chaps..........so who is this dude Will?
https://www.ridersite.com/profile.php? ... ile&u=2891
#7 Post by furygan man » Mon Feb 21, 2011 2:45 pm
Willopotomas...crops up when stuff needs doing, see various posts everywhere, one of DR's Cov buddies, has access to some cool machinery!
(*edit, posted same time as above post!)
#8 Post by Willopotomas » Mon Feb 21, 2011 6:12 pm
May have a GSX-R one up for grabs soon.. :smt001
#9 Post by Aladinsaneuk » Mon Feb 21, 2011 6:25 pm
would like to see the tilter plate.... just in case
#10 Post by D-Rider » Mon Feb 21, 2011 9:18 pm
I do remember the occasional stories of the mounting plate getting bent - usually in stories involving enthusiastic gorillas assigned to tie-down duties on a ferry.
Certainly worth checking.
anzacinexile
#11 Post by anzacinexile » Mon Feb 21, 2011 10:22 pm
D-Rider wrote:I do remember the occasional stories of the mounting plate getting bent - usually in stories involving enthusiastic gorillas assigned to tie-down duties on a ferry.
That was me then - finally convinced me to get a US stand and use the US bracket.
Let see the buggers bend that puppy :smt019
Chabby
#12 Post by Chabby » Tue Feb 22, 2011 12:07 am
Is it not the case that the standard sidestand is only deficient when you change the shock?
To my shame I've had a later yellow spring Mille shock lying in the garage next to a Firestorm stand since last summer, neither of which I've got round to putting on the bike.
I've never had a problem with the original stand - including several ferry trips and can only assume that it's when you fit a later shock with the original stand that the problems start.
#13 Post by D-Rider » Tue Feb 22, 2011 12:23 am
Nope - it's rubbish whichever shock (though one or two are happy with it)
#14 Post by Falcopops » Tue Feb 22, 2011 4:07 am
Nah, the Irish ferries gorilla bent my original stand with the original shock.
Would take a bit of doing to bend the tilter plate without bending the stand IMO.
I did use another plate with more tilt, but that got damaged on the trip from UK to Oz (started to propogate cracks at the fold).
US stand and plate now gainfully employed. Works well with either original or RSV sachs shock and by the looks of it a tad more ride height on mine will be easily accommodated
LEEMAN
#15 Post by LEEMAN » Tue Feb 22, 2011 8:59 am
Hoping this will work
Should show the angle of the 'tilter plate'
Taken on my moby so not great pic but should be ok for you to determine if the plate is b*ggered.
What ya reckon?
