Different way to modify sidestand
scottie58
#1 Post by scottie58 » Thu Jan 13, 2011 7:07 pm
Just finished bolting on and testing my modified standard sidestand. I cut off the end plate, filed 2mm off the leg and re-welded the plate back on rotated through 180 degrees. It was tacked on first, offered up then "adjusted" with a hammer so that the plate sat flat on the floor. The end plate now looks as if it should have been that way round from the factory. Bike sits at a better angle and is more supported by the stand. The stand is made from quite thick walled tubing - more than strong enough in my opinion. I know there is lots on here about alternative stands, but this is perhaps another solution ???? Will give more feedback when I test it out in the real world! :smt001
Not sure if my pic is visible (Edit by D-R: It is now) - might need some hints & tips on best way to post pics...... Hmmmm pic not easily visible, how do you experts make appear in the topic???? Help please!
#2 Post by Samray » Thu Jan 13, 2011 8:57 pm
#3 Post by D-Rider » Thu Jan 13, 2011 9:06 pm
In your case, you just needed to copy the IMG code for your picture and paste it into your post on here:
That screenshot above is from your own Photo Bouquet stuff
Falco9
#4 Post by Falco9 » Thu Jan 13, 2011 9:37 pm
Top man Scottie,
It hasn't taken you long to get in the Falco "modding" mode I see :smt003
Good on ya mate, looks like a quality job
F9 :smt006
#5 Post by Falcopops » Fri Jan 14, 2011 1:55 am
Good effort, surprising the difference a couple of mil can make.
I'm not so confident as you about the robustness of the stand tube, I had mine bent by a gorilla strapping it down on the ferry to Ireland.
I've got the US stand on mine now and it's a lot more substantial and has the foot the correct way round (what were they thinking?)
herbacious
#6 Post by herbacious » Fri Jan 14, 2011 11:24 am
Falcopops wrote:(what were they thinking?)
someone probably figured a genius way to make profit selling replacement panels and mirrors
scottie58
#7 Post by scottie58 » Fri Jan 14, 2011 5:29 pm
thanks for the info on how to post pics & editing my thread to include the modified stand
Just off into the garage for a bit of pre curry, Friday night tinkering. :smt001
FlyingKiwi
#8 Post by FlyingKiwi » Sat Jan 15, 2011 10:26 am
Good job with the modding but I always believed the main issue with the stand was that it was too far under the bike so the bike fell over it.
In which case your mod might not be enough.
See UK v US stands below.
FK
#9 Post by D-Rider » Sat Jan 15, 2011 10:53 am
Yes I agree Kiwi - this is where the Gixer stand scores too
scottie58
#10 Post by scottie58 » Sat Jan 15, 2011 7:21 pm
Certainly looks a better angle - similar to my Triumph Tiger. My mod was very quick and easy to do. Has improved it - as has putting more than 20 psi in the tyres!
anzacinexile
#11 Post by anzacinexile » Sun Jan 16, 2011 3:07 pm
FlyingKiwi wrote:Good job with the modding but I always believed the main issue with the stand was that it was too far under the bike so the bike fell over it.
My experience exactly, thats why I bit the bullet (plus the gorillas on the ferry BENT my standard bracket) and got meself a Yankee stand
NorvernFalco
#12 Post by NorvernFalco » Mon Jan 17, 2011 11:11 am
Looks good.....I'm looking at replacing the sidestand on my winter bargain and have read the posts about the AF1/Firestorm/Gixer/Bubseywoo alternatives.
I've checked the AF1 site and can see the whole assembly on there for about $160 or there abouts, but Fleabay has a few VTR stands from breakers which seem a cheaper and quicker option.
Anyone know how much the stand only costs if you order one from Americky ? And is the VTR one a true straight replacement, I'm not keen on the work needed for the Gixer one as I have the mechanical ability of a newt and need to keep this as simple as possible.
One things for sure, the current stand has to go as I have a ferry trip coming up in May and don't want to get down to the vehicle deck and see the Italian mistress lying on her side due a big wave rocking the boat. :smt017
#13 Post by Aladinsaneuk » Mon Jan 17, 2011 2:23 pm
you just change the leg from the vtr one - and adjust the kick down bar with a hammer to fit
NorvernFalco
#14 Post by NorvernFalco » Mon Jan 17, 2011 4:31 pm
Ah......fine technical adjustment required.
Thanks very much
scottie58
#15 Post by scottie58 » Mon Jan 17, 2011 8:19 pm
i know that the VTR stand fits, do any of the fireblade ones also fit?
cheers!
