Parking light fitment??
#1 Post by furygan man » Fri Dec 10, 2010 9:30 am
Just a quicky, I'll leave the complicated stuff to Rick and Co :smt003 !anyone know the bulb fitment to the front 'parking' light?
#2 Post by furygan man » Sat Dec 11, 2010 7:54 pm
40 hits and no one knows???
rick
#3 Post by rick » Sat Dec 11, 2010 8:15 pm
You mean the dips? The little 5W bulb?
Here is a pic... just taken for ya
Its a 5W 12V bulb... fits inside a little rubber boot that just gets pushed into the bottom of the cluster.
Are you going to bling this up too? Add a little colour?
HTH!
#4 Post by Falcopops » Sun Dec 12, 2010 7:32 am
Too late,
I had mine out and changed it for a LED this arvo and was all set to tell you what you need :smt009
rick
#5 Post by rick » Sun Dec 12, 2010 10:37 am
ooo i want to see pics of said bling/leds please :)
#6 Post by Falcopops » Mon Dec 13, 2010 1:45 am
Ok I'll see what I can do, although there isn't much bling. I got the bulb in a pack of 2 from Halfords years back. I used to use it as th enumber plate light so I didn't want a fragile glass bulb poking through a hole in the tail section so used the LED.
I'd say they have better products available now.
I only did it coz I could, since I run with the lights on all the time I really don't see the point in having the parking light TBH.
Anyhoo, here's a link to one I found earlier
#7 Post by furygan man » Mon Dec 13, 2010 11:38 am
Tremendous thanks Rick, need to find an equivelent LED version. Running LED's in the high beams as my standard lighting and the parking light comes on which is yellow ish so wanted to replace with LED whiter version
This is temp until i split the headlight and do some blinging and HID conversion
Finished off the rear at the weekened, funny thing is as soon as i'd done it i thought of a better way of doing it!!...always the case I guess?
#8 Post by furygan man » Thu Dec 16, 2010 6:12 pm
Rick, can you remember roughly what the diammeter of the bulb was? was it smaller than 10mm, wondering if i could get away with using a T10 LED if the holes big enough...would look myself but the bike is now at my parents
Thanks
anzacinexile
#9 Post by anzacinexile » Thu Dec 16, 2010 8:16 pm
furygan man wrote:Rick, can you remember roughly what the diammeter of the bulb was? was it smaller than 10mm, wondering if i could get away with using a T10 LED if the holes big enough...would look myself but the bike is now at my parents
Thanks
Got one fitted to my baby - it will fit OK
rick
#10 Post by rick » Thu Dec 16, 2010 9:06 pm
just had a quick look... i'd say its 10mm on the button
#11 Post by furygan man » Fri Dec 17, 2010 9:02 am
Thanks both :smt003
