Hi beam bulb
Posted: Wed Nov 10, 2010 5:54 pm
by furygan man
This may sound silly but thought i'd ask anyway!!
I like the look of the Falco with the high beam lights on, but obviously you're going to blind everyone so is it feasable/practical to place lower wattage bulbs in there and use them as daylight running lights for the purpose of being seen but not blinding people
I don't ride in the dark or tour, i know there are practical downsides but from an asthetical point of view wondered if it was worthwhile trying?
Posted: Wed Nov 10, 2010 6:11 pm
No, not really - is not only the bulb power but where the beam is directed....
Think that make sense
Posted: Wed Nov 10, 2010 6:14 pm
by furygan man
I know dumb question really, oh well!!
Bit quiet on here lately!
Posted: Wed Nov 10, 2010 8:51 pm
by anzacinexile
Get yourself some H1 LED bulbs. They will light up the headlamps but wont (cant) project any sort of beam.
Got meself a T10 base 9 LED bulb as a side light and that's powerful and bright enough to have just as a running light by itself
Posted: Thu Nov 11, 2010 2:06 am
anzacinexile wrote:Get yourself some H1 LED bulbs. They will light up the headlamps but wont (cant) project any sort of beam.
IIRC the Falco's main bulbs are all H7's. Unless you've got a cunning plan?
Posted: Thu Nov 11, 2010 8:30 am
by anzacinexile
Falcopops wrote:anzacinexile wrote:Get yourself some H1 LED bulbs. They will light up the headlamps but wont (cant) project any sort of beam.
Oopps! brain fart time
You're right, H7's it is. Getting confused with fitting HID's to me Fazer work hack
Posted: Thu Nov 11, 2010 9:10 am
by furygan man
so that's H7 fitment LED light then...okay sounds like a plan.
Thanks for that, don't feel so daft asking it now!
Posted: Thu Nov 11, 2010 4:17 pm
by anzacinexile
Posted: Thu Nov 11, 2010 4:18 pm
by furygan man
Funny that i was just looking at these, then started to look into SMD LEDs v LEDs and which was brightest etc
Posted: Mon Nov 15, 2010 2:00 pm
by furygan man
is it easy enough to solder/connect a couple of wires to a T10 bulb and wire it into the rear lighting curcuit on my homemade rear light project??
Thanks
Posted: Mon Nov 15, 2010 5:08 pm
by anzacinexile
furygan man wrote:is it easy enough to solder/connect a couple of wires to a T10 bulb and wire it into the rear lighting curcuit on my homemade rear light project??
Thanks
If you're steady with a fine tipped iron then yes but mechanically, it wont be very strong
Posted: Mon Nov 15, 2010 5:27 pm
by furygan man
From the pics i've seen on ebay there's a small wire on the outside of the plastic, i could solder to this and then wrap insulation tape around it to strengthen the bond??? I'm only being finicky because i'm about to order some on Ebay so appreciate the feedback
Posted: Mon Nov 15, 2010 8:54 pm
by anzacinexile
furygan man wrote:From the pics i've seen on ebay there's a small wire on the outside of the plastic, i could solder to this and then wrap insulation tape around it to strengthen the bond??? I'm only being finicky because i'm about to order some on Ebay so appreciate the feedback
Correct. The base is like the old filament flash bulbs (showing me age
That will give it some strength but how you going to stop it rattling around the rear light
Posted: Tue Nov 16, 2010 9:12 am
by furygan man
He he...i have a cunning plan! Just drill a hole feed the bulb through and glue gun at the rear, going to fit one either side of the cluster and connect to the brake curcuit
thanks for the feedback
