Fuel injector replacement.
Posted: Fri Nov 05, 2010 9:05 pm
by Falconihlist
How easy is it to actually replace a fuel injector on our bikes, is it a one for one swap, or do I need to time it with any other components? Any advice would be seriously appreciated on this, cheers
Posted: Fri Nov 05, 2010 10:22 pm
by Willopotomas
From the various cars and bikes i've worked on having had to replace injectors the answer is they're easy. About the same sort of hassle as changing a spark plug. All the injector is, is a small solenoid valve with a fairly high fuel pressure behind it. When the solenoid is triggered, it opens the valve momentarily thus letting fuel out. No fancy pumps or anything to time.. It's just a valve that operates at a high speed.
I've not worked this in depth on an Aprilia twin.. But it can be time consuming to get panels and throttle bodies off (if needed), but it's really a pretty easy thing to do.
