How much then?
Posted: Fri Nov 05, 2010 2:57 pm
by LEEMAN
For those in the know:
White RSV rear shock.....the one that fits the Falco
How much should I expect to pay second hand?
Posted: Fri Nov 05, 2010 4:19 pm
varies a lot
I know I paid 35 quid for hanna's in good condition - but we were lucky
I have seen extortionate prices quoted though....
as a ball park figure, I would say 35 for one that definitly needs work, 50 for an ok one, and 70 for a pristine one
Posted: Fri Nov 05, 2010 10:33 pm
by DavShill
I paid £50 for mine afew years ago. Never got round to fitting and sold it on for the same amount.
Posted: Sat Nov 06, 2010 5:16 pm
by FalcoJock
I think I paid about £70 earlier in the year but held off fitting it. Decided last week I had to fit it but aught to get it serviced first, so dropped it off at Revs and it came back on Wednesday, complete with flush valve. I suppose postage cost a bit, but I was surprised to see my credit card drained by £101.
I'll get it fitted this week, just in time for winter :-(
Posted: Sun Nov 07, 2010 8:05 am
by furygan man
Just sold mine to Phil on here for 45.00 plus 5.00 postage
Posted: Sun Nov 07, 2010 8:46 am
I think all the above are for the white spring Sachs.
Don't forget that the yellow spring sachs and the Mille-R ohlins also fit with the linkages from the donor bike (or as Mango has done, resprung and revalved to suit Falco linkages).
These shocks are probably a bit easier to come by.
Posted: Sun Nov 07, 2010 8:57 am
by furygan man
If you're still there DR, i'm currently in negotiation(!!) for a swingarm and hugger etc (gen 1), it's in really good nick, is 85.00 an okay price?
Also the second version of the switchgear looks a straight swap (i have the first gen ones) with 9 pin connector, i've seen various ones on ebay and the 1st gen ones seem to have a second 'white' connecter...the 2nd gen one i've seen doesn't have this...is it a faulty one or do they not have that part?
Posted: Sun Nov 07, 2010 11:01 am
furygan man wrote:If you're still there DR, i'm currently in negotiation(!!) for a swingarm and hugger etc (gen 1), it's in really good nick, is 85.00 an okay price?
Doesn't sound bad - A few years back I paid £50 for mine without hugger.
Hopefully it also has the guide/protector for the chain that wraps around the swingarm pivot section, the shark fin and the carrier for the rear brake hose and speed sensor cable.
If it doesn't have the usual dent on the RHS caused by a bash from the exhaust, then it sounds like a very good deal.
furygan man wrote: Also the second version of the switchgear looks a straight swap (i have the first gen ones) with 9 pin connector, i've seen various ones on ebay and the 1st gen ones seem to have a second 'white' connecter...the 2nd gen one i've seen doesn't have this...is it a faulty one or do they not have that part?
I thought it was a straight swap but never having swapped it myself, I can't be certain. I do have a set of older switchgear in the garage so I could compare but can't do that at this moment (time issues - sorry)
Posted: Mon Nov 08, 2010 8:40 am
by LEEMAN
thanks chaps, seems there can be quite a variance then
Posted: Mon Nov 08, 2010 3:04 pm
by furygan man
Cheers DR, i didn't have the bike to hand and i was bidding on something at the time, got out bid but will check my own bike for certain before i start bidding again
There are a couple of dents, there's been a few cheap ones on ebay recently so may hold out for cheaper, will be getting it powdercoated anyway...but thanks for the second opinion
