Page 1 of 3
Swingarm weights
Posted: Tue Sep 21, 2010 3:29 pm
by BenWah
Does anybody have measured weights for both the Falco swingarm and the early curvy RSV swingarm?
I'm working out whether or not to use the Mille swingarm in the Falclimber or not.
TIA
B
Posted: Tue Sep 21, 2010 6:55 pm
by kiwi_rsvr
Somewhere in the region of 5.2kg's the later 2004 version is 4.8 kg's
Posted: Tue Sep 21, 2010 9:01 pm
by BenWah
kiwi_rsvr wrote:Somewhere in the region of 5.2kg's the later 2004 version is 4.8 kg's
Is that the rsv arm? Any idea on the falco arm?
B
Posted: Wed Sep 22, 2010 4:12 am
I knew I'd seen it somewhere and I had!
both are 5.6kg according to D-Rider.
https://www.ridersite.com/viewtopic.ph ... t&start=16
Posted: Wed Sep 22, 2010 5:44 am
nod
both same weight iirc as well
there was an absolute shit fest over on af1 - most of us consider the mille arm a bling upgrade only - some one over there was adamant that there was a performance difference between the two and the mille one was superior....
Posted: Wed Sep 22, 2010 6:39 am
just looking at the difference in the ammount of metal it's surprising the RSV arm isn't heavier
Posted: Wed Sep 22, 2010 6:46 am
by kiwi_rsvr
The Mille swingarm looks massive but it is very thin walled (hence a ding in the swingarm will write them off), they were designed for racing and so the shape gives rigidity and strength while being as light as could be achieved, well back then the technology was top drawer, 10 years on things have changed but I still think visually its one of the best.
Posted: Wed Sep 22, 2010 8:27 am
by BenWah
Looks like the Mille arm I have will be going in then - it means I don't have to modify the exhaust I have (with a hammer) to make clearance for the falco swingarm at full suspension extension.
I didn't want a weight penalty though.
Sweet.
Posted: Wed Sep 22, 2010 10:31 am
by kiwi_rsvr
Compensate with Titanium axles, nuts and bolts
Posted: Wed Sep 22, 2010 10:34 am
by BenWah
kiwi_rsvr wrote:Compensate with Titanium axles, nuts and bolts
Can't do that. The whole point of this bike is that it needs to be cheap racing. Everything on it is secondhand (mostly from eBay, as was the bike itself) and there's no budget for fancy metals - especially Ti axles!
If the RSV arm is the same weight as the Falco then it goes on!
B
Posted: Wed Sep 22, 2010 11:05 am
by kiwi_rsvr
point taken
BenWah wrote:kiwi_rsvr wrote:Compensate with Titanium axles, nuts and bolts
B
Posted: Wed Sep 22, 2010 5:12 pm
Yeah - I was surprised when I weighed them that they were essentially the same.
Wouldn't claim the measurements to be fantastically accurate - weighing on bathroom scales has its limitations but at least they are decent electronic scales.
The advantage in the Mille arm is most of the weight is near the pivot point reducing the effective rotational unsprung mass ..... and it looks nice ....
Posted: Thu Sep 23, 2010 12:10 pm
D-Rider wrote:Yeah - I was surprised when I weighed them that they were essentially the same.
Best excuse I've heard yet for fitting one!!
Posted: Thu Sep 23, 2010 12:32 pm
by BenWah
The main thing for me is that I can run the RSV exhaust without having to install a bloody great ding for it to have clearance on the falco arm at full suspension extension. Looks alreet too!
Ooh, increased leverage on the swingarm weight (a reduced moment of inertia) - I can hardly weight! (geddit...?)
Bee Dubbya
Posted: Sun Sep 26, 2010 1:01 pm
by BenWah
I can reveal the differences in the weights of the Falco and RSV swingarms are as follows:
Falco swingarm including linkage - 5.96kg
RSV swingarm including linkage - 6.66kg
Measured on a digital hanging/fishing scale so pretty accurate. Thus the RSV swingarm is 700g heavier.
HTH
BW
