Tail End
Posted: Wed Aug 11, 2010 9:30 pm
by ste
Would any of the new aprilia tail tidys on offer go on the falco?
Posted: Wed Aug 11, 2010 9:52 pm
not to my certain knowledge
suggest you do a search or make one - a simple one is very easy to make
search here for tail tidy and you will find plans and all sorts of solutions
Posted: Wed Aug 11, 2010 11:01 pm
If you bend the tail tidies around a bit and drill enough holes in your bodywork they'll all fit eventually :smt001
Posted: Thu Aug 12, 2010 3:19 pm
by furygan man
Crickey even i made one!!
Drilled, corner 1 meter length of metal from B&Q and some extra bending, it's worse thinking about it and easier when you actually get on with it
Posted: Thu Aug 12, 2010 5:18 pm
if you come to the leicestershire meet - even if just a flying visit, then you can have a look at a couple of home made solutions - I can knock something up that works from two right angle brackets from B&Q.... works easily, and takes twenty minutes to fit
only downside is working out a way of doing the indicators - I have used two holes on the sub tail mount for hanna's - easy job
http://picasaweb.google.com/pete.dean/H ... 3120287762 shows it done.....
