Sat Nav Holder
Posted: Thu Aug 05, 2010 5:29 am
by mrapriliafalco
Has anyone come up with a ideal solution on carrying a sat nav yet.
Had to use one the other day and had to place the unit in my pocket!!!! Have we not got a plastic tank?I presume magnetic tank bags are of no use.
I remember subject mentioned before without a solution
Posted: Thu Aug 05, 2010 5:33 am
erm - actually quite a few solutions mate :)
easiest - clear plastic pocket on aprilia tank bag
next - dedicated mounting - aka ram ball mount as you get with the garmin systems
telferizer headstock mount - adds a large ram ball to headstock so you can fit anything you want
next dedicated plates - I recently acquired some sheet galvanised metal and made a solid mount that comes from under the clock cowl - very easy i found to do
few ideas here : https://www.ridersite.com/viewtopic.ph ... ght=satnav
Posted: Thu Aug 05, 2010 5:34 am
oh - and there are other tank bags about that we can fit - a few of them do have dedicated satnav pockets on them :)
Posted: Thu Aug 05, 2010 5:51 am
by mrapriliafalco
I remember comments the last time this was mentioned,most of us on here seamed to be anti sat nav.
I thought the tank bags would be no use due to the plastic tank.
I do not have a Garmin but a navigon and they have no official motorcycle accessory's
All the suggestions are for the Garmin satnav but I want to use my car navigon and im sure not everyone wants to fork out for a dedicated bike unit.
Posted: Thu Aug 05, 2010 7:19 am
by anzacinexile
Used a Touratech mount coupled with a couple of RAM mounts
The mount to the bike is on top of the dash. Typical of Touratech, its like a lump off the Fourth Bridge but the TomTom sure as 'ell ain't going to fly of in the mountains :smt002
Posted: Thu Aug 05, 2010 8:39 am
I use a Garmin on the bike but not a bike specific one as they are too expensive - though they do have some very good features. Bought a couple of broken ones off of ebay and made one good one out of them for very little money.
Made a mount and power supply for it several years ago.
Posted: Thu Aug 05, 2010 8:40 am
Acquire a spare car mount for your sat nav - then use that as a mount base - either by drilling through the base plate or using the ball on the back to a ram mount
Posted: Thu Aug 05, 2010 11:02 am
by Tweaker
Agree with RAM mounts for the easiest solution. They do a range of mounts, brackets, extension arms etc that should allow mounting the unit almost anywhere.
The one thing I would NOT recommend is sticking it in a tank bag! The time it takes to look down to the tank, refocus your eyes and take in the info is just toooo long. Yes, you can stop and check your route but, if it's in sight, you WILL end up trying to look at it! :smt018 Much better mounted up on the dash where you can catch a quick glance at it.
Posted: Thu Aug 05, 2010 11:22 am
Yep - I agree with that.
I am lucky in that I invested in a a starcom to go with my garmin - I find that system superb, even if for just listening to my music on long haul trips :)
Posted: Thu Aug 05, 2010 12:49 pm
by Noeli0
I agree with Tweaker, I did this with a magnetic tank bag on my prevoius bike and it was a complete nightmare could only realy check it while stopped at traffic lights. definatly mount it by the clocks.
Posted: Thu Aug 05, 2010 12:59 pm
by furygan man
I use my car satnav a Garmin 765
I made one out of a large bulldog clip, screwing the Satnav holder into one of the arms bent back, a bit of velcro and small piece of wood between the plastic and the clocks. Before you all laugh it works and the beauty is you can take it off in a couple of seconds, there's no bracket showing on the bike before or after and no tools needed (apart from the opperator!)
It's pushed up against the screen so doesn't vibrate, sits above the rev counter so nothing hidden from view and that's with a standard screen
Better to have it as high up as pos, didn't get on with having it in a tank bag as had to keep looking down. Has earphone socket too which is a bonus, right i'll stop waffling and let the sensible solutions carry on!
Hope to take pics at weekend
Posted: Thu Aug 05, 2010 9:58 pm
by herbacious
I got a tankbag
however I found that the sat nav got worryingly hot and also glare was a problem
the solution was a twig that was rolled up in a sheet of rubber non slip matting from pound stretcher (just like that oxford stuff but only £1)
worked a treat :)
satnav was the biggest screen one i could get from argos for £100
Posted: Fri Aug 06, 2010 8:24 am
by furygan man
Wood you have a pic of that..?
Posted: Mon Aug 09, 2010 2:12 pm
by philgro64
Would agree tankbag not the best option! too many look down moments with left gloved hand shielding the glare(even when its not that sunny). :smt011
Posted: Mon Aug 09, 2010 6:33 pm
by old git
spare arm/holder off evilbay..
1./ cut off sucker thingie.
2./ drill 2 holes in large bulldog clip ( the type with fold back arms)
3./ with strip of metal/plastic whatever bolt arm (of satnav) to buldog clip.
4./ fix buldog clip to mantelpiece above the clocks.
simples .......(meekcat squeek)
