Missing exhaust emission plug
gavhowe
#1 Post by gavhowe » Sun Jul 18, 2010 1:27 pm
Hello, I have lost one of the exhaust emission plugs (CO plugs) from the rear header. Does anyone know what thread they are?? Dont really want to disturb the front one to measure it. I have temp plugged the hole with part of old spark plug, but its not the right thread so does not screw in correctly.
Thanks
#2 Post by Nooj » Sun Jul 18, 2010 10:38 pm
10mm I believe, course pitch.
#3 Post by Falcopops » Mon Jul 19, 2010 4:04 am
Can't help much, but I got replacements from an old fasteners place in Surrey. The bloke was pretty impressive at identifying stuff, but was a bit confused at first as he reckoned it was a thread that was normally used in plumbing applications.
He gave me some very slightly tapered grub screws that he suggested I didn't overtighten so they wouldn't split the boss and use thread lock. That was about 6 years ago and they're still good.
Take the other one out and try to get a match at a proper plumbers merchants. Then buy a bunch as they'll probably cost 30p each
#4 Post by Nooj » Mon Jul 19, 2010 9:49 pm
They're not a plumbing fitting, they're a metric thread. 99.9% sure they're M10.
anzacinexile
#5 Post by anzacinexile » Tue Jul 20, 2010 7:20 am
Nooj wrote:They're not a plumbing fitting, they're a metric thread. 99.9% sure they're M10.
I'm with the boy with the hairy legs, M10 taper thread :smt002
#6 Post by Samray » Tue Jul 20, 2010 3:30 pm
Aren't plumbing fittings taper thread? :smt020
and european and american taper threads aren't compatible in some sizes.
gavhowe
#7 Post by gavhowe » Tue Jul 20, 2010 3:33 pm
I found a plug at work its 1/8 BSP thread
#8 Post by Kwackerz » Tue Jul 20, 2010 4:37 pm
1/8BSP is 9.5mm thereabouts, so chances are it is M10
:smt001
#9 Post by Willopotomas » Tue Jul 20, 2010 5:39 pm
Kwackerz wrote:1/8BSP is 9.5mm thereabouts, so chances are it is M10
:smt001
Close, but no cigar. They're a different pitch.. Meaning you chance either stripping the screw or cracking the insert. Not heard of a taper thread on metric sizes.
Pitch of M10 is 1.5mm, Pitch of 1/8 BSP is 0.90mm. 0.6mm is a massive distance in engineering terms.. Might not sound a lot, but it's huge when it comes to screw threads.. :smt002
Also, the TPI of 1/8 BSP is 28, and i think M10 is 24 TPI..
#10 Post by Kwackerz » Tue Jul 20, 2010 7:08 pm
Oh indeedy, however with the 1/8 being a smaller diameter, it would fit in the hole quite well, regardless of tpi and pitch.
How many modern bikes, especially european, use a British Standard Pipe thread on their components? I'll have a quid on it being a metric thread..
#11 Post by Willopotomas » Tue Jul 20, 2010 7:13 pm
One's on the VFR were BSP.. had to replace a few before it went.
It's fallen out.. So chances are it is metric..lol.. :smt003
anzacinexile
#12 Post by anzacinexile » Tue Jul 20, 2010 8:20 pm
Right - just checked the parts catalogue and its a 10mm taper standard pitch :smt019
gavhowe
#13 Post by gavhowe » Fri Jul 23, 2010 11:53 am
Interesting, well the 1.8BSP plug is installed. I thought all metric thread were parallel, and the plug seals on a washer too. If anyone has a spare standard plug I will happily put it on the shadowgraph at work and work out what it is exactly. BSP thread is the standard used across europe the the pneumatic fittings industry and the states use NPT.
#14 Post by Willopotomas » Fri Jul 23, 2010 5:35 pm
a Shadowgraph.. wow.. cool.. I thought I was the only one who still had one.. :smt003
#15 Post by MartDude » Fri Jul 23, 2010 11:05 pm
Fantastic - a thread thread. When I were a lad - all we had to bother about were Whitworth and BSF
