Eek another clutch problem...sorry!
Posted: Thu Jul 01, 2010 12:55 pm
Had a ride out yesterday and found getting neutral a real problem which got worse, even getting out if first or second was a real effort, the only time it would got into neutral was if i switched the bike off. Same thing this morning, when i put it in gear with the clutch full in it wanted to move forward!!
Called out AA, he bled the clutch and thinks it might be a leak from the cluch slave cylinder, when i first picked up the bike i stored it through the winter and noticed a small oily deposit leaking onto the top of the side stand area, when i used the bike in the spring i had to top up clutch level slightly
The AA guy said keep an eye on it but just a bit worried to go on any journeys, is it something someone (with no knowledge!) or drop into a mechanic and get him to investigate??
All comments welcome as ever
