MOT checks - rear reg light
Posted: Wed May 05, 2010 9:31 pm
by arizonabay
With my tail tidy lost in transit from the German fella, I have decided to fabricate my own (without a reg light).
All the mot test notes/manuals I've checked say nothing specific about a rear registration light - they do however say you need a rear red reflector. Does anyone know for sure if the registration light is definitely required for an MOT pass?
Posted: Wed May 05, 2010 9:33 pm
by anzacinexile
Well, the buggers failed mine one year when the bulb failed and I hadn't noticed
Posted: Wed May 05, 2010 9:39 pm
There could be a difference between needing to be working if there is one, and needing to have one. :smt001
Posted: Wed May 05, 2010 10:55 pm
for a full mot you need a plate light
for a daytime only mot you don't
i use the led number plate bolts - about a tenner from evil bay
Posted: Thu May 06, 2010 7:52 am
by arizonabay
Cheers for the replies.
I just called the mot test centre I have always used and they have confirmed that a number plate light is not required for a full mot pass. :smt003
Posted: Thu May 06, 2010 8:35 am
hmmm
sounds like you have a good test centre - i have failed them in the past for a none working light....
from http://www.ukmot.com/1-1.asp
. With the side and rear lamps switched on, check that the rear registration plate lamp(s) is
(PASS) (FAIL)
a. fitted a. not fitted
b. working b. not working
c. does not flicker when tapped lightly by hand. c. flickers when tapped lightly by hand.
Posted: Thu May 06, 2010 9:00 am
by arizonabay
Interesting... not sure what is meant by "multiple number plate lamps" - but if the tester is happy, who am I to complain :smt002
Posted: Thu May 06, 2010 4:51 pm
by joecrx
mine failed for not working 2 years ago , strange , i supose if you have one fitted it has to work ,
Posted: Thu May 06, 2010 5:19 pm
by tommy
I've not got one. Went through all MOTs fine
Mr MOT man said its a fail if your light doesn't work, but its not a fail if you don't have one
Isn't there a similar rule regarding spare wheels on cars?
Posted: Thu May 06, 2010 5:58 pm
by fastasfcuk
tommy wrote:I've not got one. Went through all MOTs fine
no spare wheels do'nt come into it. unless you've got a space saver fitted for the test.
Posted: Thu May 06, 2010 8:15 pm
Mine doesn't have one and has passed without one for the last two years. Did it change when the new MoT's were bought in?
Posted: Fri May 07, 2010 9:22 am
by joecrx
im sure its the same with indicators it wont fail if they are not fitted but if they are the would have to work
