One for the Techos
Posted: Tue Apr 13, 2010 2:17 pm
Ok after all my spannering and gnashing of teeth etc i have stumbled on a wee problem.
Starter motor (mille) replaced, sprag and alternator investigated at the same time. The resistances of the alternator (stator) were outside the values specified in the manual of 0.2 - 0.5 ohm (mine read 0.8) so I am in the process of replacing it.
The arrow on the flywheel tells me that it should turn anticlockwise, however having pulled it off to inspect the sprag and replaced it all back again I was a bit confused about which direction the sprag should spin freely in and now I'm lost as to whether I've put it back on correctly. (yes yes I should have marked it i know)
The starter cog spins anticlockwise, the geared cog spins clockwise, the idler in turn spins anticlock which in turn spins the cog at the rear of the flywheel clockwise (against the arrow on the flywheel)
Questions:
Could i have replaced the starter motor with one that turns the opposite way(ie are all Aprilia starters the same) and in turn put the sprag on the wrong way round?
Should the flywheel always turn in the direction of the arrow even under starting conditions.?Or does it start by going backwards then spins forwards IYSWIM
The beast has not yet been out this year and I'm missing her desperately despite having a mates 07 plate Tuono to play on.
Cheers for any help.
Andy
Questions:
Andy
