light weight rider....
Posted: Wed Mar 31, 2010 11:17 pm
getting close to letting malteaser loose on the falco but, sudden thought
bearing in mind she is about 9 stone in leathers, and with white spring mille shock fitted - are we going to be wise to fit a steering damper ?
would welcome others thoughts as i am being careful....
she already counter steers on her sv....
Posted: Wed Mar 31, 2010 11:37 pm
Dunno if a steering damper is going to be the main problem, at that weight you might find the suspension too stiff, although if you can get the sag set up with her on it you might be ok
Posted: Thu Apr 01, 2010 12:05 am
Take a trip down to Stowmarket to MC Technics and get them to set it up for her? Fairly straight run down there so a bit of careful riding until theyve done their magic?
http://www.mctsuspension.com/
Posted: Thu Apr 01, 2010 5:49 am
I know them Tim - trouble is they are getting very popular !
Was planning to get griff to do it at aprilia day - am hoping that though taxing from today, to let her loose on the bike over the next few weeks - ie, not many miles at a time....
Posted: Thu Apr 01, 2010 6:30 am
Yeah I noticed their prices have risen a little, still money well spent.. I assume then it's a case of 'if you can get a slot' !
Im sure she'll be fine mate. There's lots of lightweight chicks racing in Bemsee on powerful bikes and half the time they do it better than the blokes.
She rides an SV, is used to how V Twins bite rather than jumping off an CBR400, let her get on with it, she'll be fine.
Does your concern lie with the bike or the burd or the fact once youre on similar machinery, her power to weight ratio is going to make you have to work to keep up?
She will be fine just remind her about the shock all the time til its set up.
Im sure Malteaser will be along shortly to slap you for worrying
Posted: Thu Apr 01, 2010 7:53 am
roflmao - having to work harder to keep up lol
her falco is fairly stock... so no problems... oh, i may accidentally forget to change rev limiter indicator - wether or not she notices of course...
is about getting the bike set up correctly - i am not a suspension expert lol
Re: light weight rider....
Posted: Thu Apr 01, 2010 8:07 am
Falcopops wrote:Dunno if a steering damper is going to be the main problem, at that weight you might find the suspension too stiff, although if you can get the sag set up with her on it you might be ok
Yep - I'd agree with that.
As does everyone - ever since bikes were invented .... you can't initiate a turn without.
It's just there's a lot of bollox talked these days that suggests it's something new and different.
Posted: Thu Apr 01, 2010 8:12 am
by HisNibbs
I'd doubt very much that a steering damper will be a necessity.
I've just fitted one but not because I felt I had to. Eaven with an arse up nose down set up I was only getting the hint of a shake cornering reasonably aggresively at well over the ??? on very bumpy surface changes.
Getting the sag in range is IMHO is the only prerequisite.
Mind you I'm no "lite weight" any more......
Posted: Thu Apr 01, 2010 8:28 am
by FlyingKiwi
If your that worried why not re-restrict it
I'm sure she'll appreciate it
Posted: Thu Apr 01, 2010 8:34 am
HAVENT you fitted the smoothing plate?
http://www.alphatechniksql.alphaplanweb ... e3=Aprilia
She'll need that before she gets out on the road. smoothes out the power delivery.. you know the judder caused by the fact the tilt switch isnt on the level cos of her being under 11 stone.
you could probably make that to be honest, rather than buy it..
Posted: Thu Apr 01, 2010 8:41 am
So how do you fit it? What goes where?
Posted: Thu Apr 01, 2010 8:43 am
2 discs under the TBs and the Clip on the throttle cable? I stuck it into Google translate as my German isnt as good as it used to be....
Posted: Thu Apr 01, 2010 9:38 am
by mrapriliafalco
My wife is tiny,sometimes she takes out the falco and her only complaint is being heavy when stationary.
She scares the life out of me when she pulls away but after that she is fine.
Posted: Thu Apr 01, 2010 9:43 am
I'd tend to think that Jadaris might even need a softer spring installing. Once you've wound preload off to zero, you can't go any further. The same may also be true of the front forks, as ISTR that the Falco has fairly heavy rate fork springs. I know that Race-Tech have a handy calculator that you can use for this on their site, although I've heard some people say that the spring rates that it recommends are still on the firm side.
According to their site, standard fork spring rate is 1.05 kg/mm, and their recommendation for a 125lb rider is approx 0.85 kg/mm. Even that sounds a tad high to me. Their calculator doesn't seem to work for the rear shock, so can't help on that...
Posted: Thu Apr 01, 2010 3:23 pm
YOU are letting HER loose on it? Just who's bike is it??? Award yourself a hard slap and a knee in the 'nads from all the women riders in the world today
