HELP, losing Clutch Fluid
Posted: Sun Dec 13, 2009 6:45 am
by clint
I am losing clutch fluid, have to top it up about every 2 weeks, i have not stripped it down yet, not got the confidence. can i just get a seal kit and replace them or do i have to buy/replacement cylinder?
any advice/help would be greatly recevied
Thanks
Clint
Posted: Sun Dec 13, 2009 8:41 am
by Dusty
I had the same problem, although I also had a drip on the floor. The fluid can mix with all the gunk around the front sprocket preventing it from dripping to the deck. I replaced mine with an Aprilia seal at a cost of about £12 and this cured the problem. Since then, some clever fellows have sourced a cheaper alternative:
https://www.ridersite.com/viewtopic.php?t=4982
Posted: Sun Dec 13, 2009 9:02 am
by clint
Thanks for the reply, is it a fairly easy job to replace, i know about bleeding brakes etc, but never done a clutch cyl, have read it can be a bit of a pain
Posted: Sun Dec 13, 2009 10:04 am
by Dusty
It was very easy to replace and I had no problem bleeding it although like you, I have heard that it can be problematic. The biggest disappointment was that the nice new clutch fluid turned black again after a couple of weeks! But, that seems to be a common Falco issue that doesn't affect the clutch operation. I'll change my fluid again in the spring.
Posted: Sun Dec 13, 2009 2:08 pm
by joecrx
you can go down the aftermarkit mpl rout , makes the clutch lighter ,
i might add after 9000 miles the seal has went on my mpl and its not a job you can do yourself , it goto go back to germany
Posted: Sun Dec 13, 2009 5:01 pm
by fastasfcuk
joecrx wrote:you can go down the aftermarkey mpl rout , makee the clutch lighter ,
i mught add after 9000 miles the seal has went on my mpl and its not a job you can do yourself , it goto go back to germany
you been on the whisky joe.
Posted: Sun Dec 13, 2009 6:13 pm
by joecrx
aye:smt005
Posted: Mon Dec 14, 2009 1:11 pm
[[/quote]you been on the whisky joe.
[/quote]
Keep up Ian,
He's still on the Advent Calendar until Christmas!
https://www.ridersite.com/viewtopic.php?t=5700
Posted: Mon Dec 14, 2009 6:28 pm
by joecrx
thats well finished , didney last long
Posted: Tue Dec 15, 2009 8:51 pm
by sfoley1
Clint
I had this problem and bought a new seal for a fraction of the price that Aprilia charge.
It was D-Rider (as ever!) who pointed me in the right direction. My local bike shop told me I needed a new slave cylinder. I printed off a thread from here and gave it to them along with the £2.50 seal and hey presto - sorted for £22.50. half hour labour and the bit.
See my old post
https://www.ridersite.com/viewtopic.php?t=5372
Posted: Fri Jan 01, 2010 7:10 pm
by Thumper
Just a get out of trouble tip, it's possible to do a temporary repair on a slave seal by adding a little plumbing PTF tape under the seal in the grove of the piston. This will bring more of the worn seal lip in contact with the bore. I rode over 6k miles this way with no further fluid lose until I managed to get a new one.
Most of the time it's just crud in the bore that leads to a bad seal anyhow. Clean and polish before refitting with mentholated spirit avoid using potrolem based cleaners, not good for rubber seals
Posted: Sat Jan 02, 2010 12:45 pm
by Falco9
I have a spare slave cylinder in the garage (I bought it as a spare but have never needed it) it is 2nd hand but I reckon it should be fine
£20 delivered if you want it. (If Clint doesn't want it, its then available to anyone else)
F9
Posted: Mon Jan 04, 2010 5:58 am
by clint
Falco9 wrote:I have a spare slave cylinder in the garage (I bought it as a spare but have never needed it) it is 2nd hand but I reckon it should be fine
F9
F9,
Thanks for the reply, am going to have a look at the cyl as soon as the weather warms up a little up here in scotland. If the offer still stands i will be in touch once i have checked out the problem.##
thanks
clint
