any body want these for christmas
Posted: Fri Dec 11, 2009 3:17 pm
by fastasfcuk
Posted: Fri Dec 11, 2009 3:41 pm
by Olig7475
That’s a lot of dosh for a set of OZ's considering for just over a grand you could have had the carbon wheels!!!
Would a set of 2004's fit our birds, weren't they all radial brake models by then?
Posted: Fri Dec 11, 2009 4:32 pm
It also depends if they're the genuine OZ wheels or the Aprilia-made lookalikes. Only the earlier bikes had the genuine OZ wheels. The lookalikes were actually heavier than the standard Brembo wheels, I believe...
<edit>
Just done a bit of searching and turned these posts up. Sounds like the proper information...
https://www.ridersite.com/viewtopic.ph ... t&start=20
Posted: Fri Dec 11, 2009 5:01 pm
They say they're from the Factory, so they should be good ones - though the front one won't fit - can't remember whether it needs spacers or needs machining down ... I've an idea it's the latter.
Posted: Fri Dec 11, 2009 6:07 pm
by fastasfcuk
i've read somewhere that you need spacers to line the disk's up with the callipers.
Posted: Fri Dec 11, 2009 9:16 pm
Alternatively swap the forks for a nice set of Ohlins with radial brake mounts and job's a goodun!
