rsv swingarm and shock
Posted: Sat Nov 14, 2009 12:30 pm
by roosterNI
hi i'm sure this subjec has been covered but i can get a 07 rsv swingarm shock and linkage for reasonable money, the shock is a yellow spring sachs adjustable unit apparently, question is, will it slot straight in?
Re: rsv swingarm and shock
Posted: Sat Nov 14, 2009 12:39 pm
roosterNI wrote:hi i'm sure this subjec has been covered but i can get a 07 rsv swingarm shock and linkage for reasonable money, the shock is a yellow spring sachs adjustable unit apparently, question is, will it slot straight in?
It has been done but it's not so straightforward.
One of the bigger hurdles is the limited clearance between the top of the swingarm and the battery box beneath the seat. Solutions have been to cut the battery box off and relocate the battery to the seat hump.
I've got some info somewhere on how to do the mod - if you are keen or crazy enough to do it, I'll find the info for you.
Some of the people that have done this are Pierre from this forum and Hansie from the AF1 forum. There are others too but these were the first names that came to mind.
Posted: Sat Nov 14, 2009 2:25 pm
by roosterNI
no dont go out of your way, reason i was asking, i done a track day realized the shock really is scrap, phoned a breakers, who has a 07 mille sitting, offered the swingarm shock and linkage for 300, thought that was a good deal, in two minds what to do.
Posted: Sat Nov 14, 2009 3:03 pm
Unless you want a lot of hassle then wait for kit from one of the earlier Mille's (pre 04) to come up. Tuono up to 05 is the same btw.
You can fit the shock and linkage (though the earliest Milles hasd the same linkage as the Falco) or throw in the swingarm too for a bit of bling.
Posted: Sat Nov 14, 2009 11:19 pm
by Falco9
If your into "bling" I have a 04-09 mirror polished swinging arm that I'd be willing to sell. No linkages though, just the arm itself with all the bearings fitted
It is very shiney though
F9 :smt006
Posted: Sun Nov 15, 2009 7:30 pm
by roosterNI
woooow!!!! that is shiinneeeeeyyyy!! its not bling i'm after, think i'm just gonna go with the shock. cheers for offer but.
Posted: Fri Dec 11, 2009 8:37 pm
by roosterNI
ok raising this subject again, 99-03 rsv or tuono swingarm should bolt straight into my falco? fitted 04 tuono shock and linkage, superb job.
Posted: Fri Dec 11, 2009 9:12 pm
Yep - a straight swap and the 04 Tuono shock & linkage will combine well.
Posted: Fri Dec 11, 2009 9:14 pm
yes
straight fit
do the bearings while you are at it
the rear brake line will fit - or get a braided one for a tuono or mille
Posted: Fri Dec 11, 2009 9:49 pm
by roosterNI
just put braided hoses on all round so happy days. cheers folks!
