rsv swingarm and shock
hi i'm sure this subjec has been covered but i can get a 07 rsv swingarm shock and linkage for reasonable money, the shock is a yellow spring sachs adjustable unit apparently, question is, will it slot straight in?
Re: rsv swingarm and shock
It has been done but it's not so straightforward.roosterNI wrote:hi i'm sure this subjec has been covered but i can get a 07 rsv swingarm shock and linkage for reasonable money, the shock is a yellow spring sachs adjustable unit apparently, question is, will it slot straight in?
One of the bigger hurdles is the limited clearance between the top of the swingarm and the battery box beneath the seat. Solutions have been to cut the battery box off and relocate the battery to the seat hump.
I've got some info somewhere on how to do the mod - if you are keen or crazy enough to do it, I'll find the info for you.
Some of the people that have done this are Pierre from this forum and Hansie from the AF1 forum. There are others too but these were the first names that came to mind.
Unless you want a lot of hassle then wait for kit from one of the earlier Mille's (pre 04) to come up. Tuono up to 05 is the same btw.
You can fit the shock and linkage (though the earliest Milles hasd the same linkage as the Falco) or throw in the swingarm too for a bit of bling.
- Falco9
If your into "bling" I have a 04-09 mirror polished swinging arm that I'd be willing to sell. No linkages though, just the arm itself with all the bearings fittedroosterNI wrote:hi i'm sure this subjec has been covered but i can get a 07 rsv swingarm shock and linkage for reasonable money, the shock is a yellow spring sachs adjustable unit apparently, question is, will it slot straight in?
It is very shiney though
F9
