clutch pin/rod and barrel
Posted: Mon Jun 15, 2009 7:16 pm
by scottyni
looking for the plunge rod and barrel if any spare ??????
not paying for a full lever (£80) when all i need is that little part.
tried a few places and no joy, only option is too make my own (pin/rod) one.
Posted: Mon Jun 15, 2009 9:18 pm
by Falco9
Mark,
Keep looking on fleabay. A number of levers come up on there all the time. Worth bearing in mind that this is the same lever used on loads of Ducatis as well, so worth scanning for them as well.
Get the seller to send a photo to make sure your bidding on ther right one though
F9 :smt006
Posted: Tue Jun 16, 2009 9:58 am
by shootmyscoot
hi
i did post a solution on the aprilia forum for you when mine broke,
i drilled the retsainer and used a large pop rivit
sms
Posted: Wed Jun 17, 2009 6:28 am
by scottyni
sms
how good a fit into the barrel was the rivet and the pin part was strong enough for the job
got a pin barrel and lever part coming from oz, just hope i can free it and use it in my black levers i bought.
if not then i'll go down the rivet way
Posted: Wed Jun 17, 2009 10:13 am
by shootmyscoot
it fitted perfectly, i just left some lenth on the rivit and folded the wing back slightly, i wouldnt recommend it for long term use,
however i still using it 2yrs on, as i couldnt find 1 any where.
sms
