Cooling Fans - HELP!!
Posted: Thu Aug 21, 2008 7:49 pm
by windsor
Dear All
Got a problem with the cooling fan on my 02 Falco - Similar to Sidestands problem a few weeks back.
Problem is when temp hits 98 deg the RH fans only cuts in - both have cut in in the past.
LH Fan was very tight when I removed it to have a look, so bought another one off Ebay for a tenner and this works ok - tested it by connecting to car battery.
Dont think it can be a faulty Fan switch as I'm told both Fans work of the same switch and fuse.
The initial connection also appears ok.
I would really appreciate anybodys thought or suggestions
Posted: Thu Aug 21, 2008 8:51 pm
If the new working fan does the same as the old one on the bike, and the RH one still works fine, I'd say there's a break in the circuit, either a bad connection on a terminal, a crimp that's come loose or a broken wire to the LH side of the bike.
