With only light presure on the front brake leaver and at low speed's when coming to a halt I can feel the leaver pulsing as if the front disc's are warped, after reading several old post's here and else where it seem's I had already done most of the things that have been sudjested. I've put new disc's and pads on, made sure the calipers and piston are clean but still the brakes aren't right.
I did read on a couple of posts that DOT 5 can eat the seal's in the master cylinder and those on the piston's,( yes you've guesed it ,I have dot 5 brake fluid front back and clutch).
So I've now changed all the fluid, brakes still not right so my next coarse of action is to change the seals in the master cylinder and brake pistons, only it seems brenbo don't seem to sell them.
That is unless any one knows different, or where I could send them to be overhauled ?
