under seat noise
scorpio24v
under seat noise
#1 Post by scorpio24v » Wed Mar 05, 2008 7:37 pm
Hi guys,
I have a strange noise under the seat, rear of fuel tank area. its sounds like a ball bearing rolling around when i move the bike upright from the sidestand and then again when i put the bike back on the side stand. Any ideas? :smt120
Firestarter
Twisted Firestarter
#2 Post by Firestarter » Wed Mar 05, 2008 8:00 pm
Probably a bolt come loose and has dropped into one of the trays, happened to me a little while ago, IIRC found it in front of the battery compartment. Never did find where the bolt came from :smt017
That being said, get the seat off and have a proper good look - anything falling off a bike may lead to something nasty, and of course I could be wrong and it's not a bolt!
back_marker
#3 Post by back_marker » Wed Mar 05, 2008 9:29 pm
Yeah, what he said. There is a tray right below the point where the tank pivots which is very difficult to see into. It is where that silly flap that sits between the shock and the back wheel bolts on amongst other things. Would be very easy for something small and hard to be stuck rolling around in there.
- Steve McQueen
#4 Post by Falcopops » Wed Mar 05, 2008 9:29 pm
Take the seat off and lift the tank. There's a flat tray under the back of the tank might be something rolling around there.
#5 Post by joecrx » Wed Mar 05, 2008 9:55 pm
i chsnged my battery a while back and droped the small nut a few times ,i had spares to use, but never found the ones that fell :smt017 do you think there in the same place ?
#6 Post by Samray » Wed Mar 05, 2008 10:00 pm
That must be it. Turn the bike upside down and shake it. :smt002
graham0071
#7 Post by graham0071 » Wed Mar 05, 2008 10:02 pm
Samray wrote:That must be it. Turn the bike upside down and shake it. :smt002
:smt003 :smt003
banksie
scorpio24v
#8 Post by scorpio24v » Wed Mar 05, 2008 10:11 pm
found it, a nut is indeed in that tray under the nose of the tank, i can just see it but cant get at it. How the hell do you get access to the tray? I thought the tank lirts from the front, so that wont work, i think the rear needs to be lifted.
exupmonkey
#9 Post by exupmonkey » Wed Mar 05, 2008 11:41 pm
scorpio24v wrote:found it, a nut is indeed in that tray under the nose of the tank, i can just see it but cant get at it. How the hell do you get access to the tray? I thought the tank lirts from the front, so that wont work, i think the rear needs to be lifted.
If you can see it then one of those telescopic magnet doohickies might help, kind of like a small magnet stuck on the end of a car aerial...real handy if you have more thumbs than fingers :smt003
scorpio24v
#10 Post by scorpio24v » Thu Mar 06, 2008 8:32 am
Got one of those magnet on a sticks, and retrieved one item, a kind of flat top hat with a hole in it, unfortunately there is another bit, the screw that goes through the hole, prolly made from Stainless steel, therefore not magnetic, so 50% fixed.
Firestarter
Twisted Firestarter
#11 Post by Firestarter » Thu Mar 06, 2008 9:26 am
If you find where it's come from, let me know - it's probably fell out of the same hole as mine did, and I've not found where that is yet :smt009
scorpio24v
#12 Post by scorpio24v » Thu Mar 06, 2008 5:32 pm
I lifted the tank, and could just get my hand in to the tray to remove the stainless steel cap head screw, identical to that which holds the front part of the tray, the little top hat thing acts as the spacer. I guess they drop one in at the factory on purpose to confuse the enemy :smt001
so problem solved, buy an Aprilia and get free spares :smt002
