Will this fit my Fightalco?
Posted: Thu Jan 24, 2008 9:04 pm
by sabestian
Hi guys. I'm preparing for a big conversion of my Fightalco to Mille exhaust and swinger. I've got my exhaust headers, pipes, oil tank, bellypan, etc. I need to collect all the bits to do it all in one, that's including new paintwork. I'm still missing an exhaust hanger, Mille oil cooler with hoses (for now I hope the Falco one will fit with a bit of DIY hose-work).
Anyway...
Will this fit with Falco rear subframe with a Mille exhaust?
Posted: Thu Jan 24, 2008 10:29 pm
by Falco9
The short answer is NO
I had to have my exhaust hanger made up for me when I converted my Falco to the Mille system. The reason is that the Falco subframe runs at a lower angle than the Mille, so the std brackets for either bike won't fit.
However I reckon that bracket could be "adjusted" to fit, maybe shortened with another hole drilled in it. If the price is right I reckon it could work
The Falco oil cooler will work fine,as you say just a bit of hose work required, it's a lot easier if you can drop on a Mille one though (and neater, if you don't have a belly pan to hide everything)
F9
Posted: Thu Jan 24, 2008 11:58 pm
by Pierre
If you look at your standard hanger its got a webbing shape similar to that on the back of it. I drilled/hacksawed/dremeled/filed mine out to get the hollow effect. Not as nice as that one you show although you could make a neater job than I did, but the price was the decider for me
Posted: Fri Jan 25, 2008 3:35 pm
by sabestian
Pierre wrote:If you look at your standard hanger its got a webbing shape similar to that on the back of it. I drilled/hacksawed/dremeled/filed mine out to get the hollow effect. Not as nice as that one you show although you could make a neater job than I did, but the price was the decider for me
I'm a dentist, I should be alright with drilling :D
@F9 where do you get high temp oil resistant hoses on this island?
Posted: Fri Jan 25, 2008 3:45 pm
by Falco9
Luckily all the hoses were included with my oil cooler purchase (thanks Treetops) but I'd try the breakers yards (Ken Urwin in Thorne isn't bad) I have friends who've sourced the original Aprilia oil lines from breakers for just a few quid.
I'm sure Pierre knows a few sources as well
F9
Posted: Fri Jan 25, 2008 6:28 pm
by bigun
Nah, Pierre just uses straws pinched from the pub, a bit of chemical metal and a clout with a big hammer. Normally sorts it!
(sorry m8, couldn't resist)
Posted: Fri Jan 25, 2008 10:02 pm
by Goldie
bigun wrote:Nah, Pierre just uses straws pinched from the pub, a bit of chemical metal and a clout with a big hammer. Normally sorts it!
Nah, he buys the stuff off ebay after the visiting the pub, then he uses the big hammer to force the the crap to fit!!!
(Sorry P
, as above)
Posted: Sat Jan 26, 2008 12:44 am
by Pierre
ahhh, my life is so predictable. Mind you i dont pinch the straws, I'm usually grabbing at them
Anyway, BACK ON TOPIC, see if you can see the exhaust hangers I've put on this piccy seb, hope it helps
oh ffs wont resize
Posted: Sat Jan 26, 2008 1:07 am
Well if you do mess it up, you can always fill it up with a mercury-based paste!
Posted: Sat Jan 26, 2008 5:06 pm
by sabestian
Naah, I'd just rip it off... That always helps.
Posted: Sat Jan 26, 2008 5:09 pm
by sabestian
Pierre, WHAT THE HELL? Have I missed something?
Exhaust hangers
Posted: Sun Jan 27, 2008 11:43 am
by GregD-UK
OK Pierre,
I know u go on the track alot, but, getting ur knee down in ur own garage is abit extreme
Posted: Sun Jan 27, 2008 12:24 pm
by Syltiz
Pierre wrote:ahhh, my life is so predictable. Mind you i dont pinch the straws, I'm usually grabbing at them
oh ffs wont resize
nutter
Posted: Sun Jan 27, 2008 5:25 pm
by Pierre
thats supposed to be a smaller piccy ffs, stupid interweb.
Its my new way of changing the rear shock.
Put bike on bench.
Jack bench up
Take weight with rachet straps on overhead beams
Let bench down a bit
Change shock
Release ratchet straps
Bang.
Insert *Lift bench up to take weight* somewhere in there cos I forgot. Never drink stella and twirl the tools
Anyway , BACK ON TOPIC, the exhaust hangers are on the bike in the background seb, top left of photo, yea just there
I could take a piccy unless youre dedicated to spending money on bling
edit: can anyone see my special exhaust packing
Posted: Sun Jan 27, 2008 6:02 pm
by bigun
Fooking hell Pierre!! How far did it fall?
