Syltiz
- Chaos Merchant
#1
by Syltiz » Sun Sep 09, 2007 6:20 pm
...only to find i was sent incomplete kit. No washers, spacers and screws
#2
by Aladinsaneuk » Sun Sep 09, 2007 7:09 pm
shouldn't need any??
the allen key bolt that goes through the rear seat grab rail - remove that and then reverse it - so the allen key goes from under the rear seat out - then it screws into the pannier frame
the other two mount points are already there - just undo the bolts, offer up and tighten again
that all make sense??
Syltiz
- Chaos Merchant
#3
by Syltiz » Sun Sep 09, 2007 7:24 pm
According to the supplied instructions, I need a spacer, washer and different bolt for the footrest mounting point. I can mount the rear grab handle and exhaust points, but the footrest mounting clearly needs a spacer and a longer screw.
Did yours not need?
#4
by D-Rider » Sun Sep 09, 2007 7:48 pm
Yep - absolutely correct - spacer and longer bolts needed for the mounting at the top of the footrest bracket.
FlyingKiwi
#5
by FlyingKiwi » Sun Sep 09, 2007 7:48 pm
Mine didn't have spacers or longer screws but when I fitted it I did put a couple of washers in at the top of the peg hangers to give a mm or 2 clearance.
#6
by Aladinsaneuk » Sun Sep 09, 2007 8:57 pm
i didn't need the spacers.... but i may have had longer bolts already...
