#10
by HowardQ » Tue Jul 17, 2007 9:40 pm
Welcome Stainless,
Same answers as most of the others.
Sidestand - see threads on GSXR units.
If you want tyres that give good grip all year round and last well use BT 020s or the latest 021s which I also feel are even better.
But others like Pilot Road and Diablos are aslo well thought of.
Belly pan - Skidmarx easy to fit, see photos in Gallery/Ridersite Falcos etc.
Swing arm - If you must go banana shaped, go for one off an earlier Mille (99 - 03 I think), as it is much easier ti fit, but it does absolutely nothing for the handing, only the looks. I may be one of the few people who thinks the stadard swinger looks better on a Falco as it matches the straight twin spar frame.
As for the shock, you may improve it a bit whilst you sort things out by upping the preload and stiffening it up.
Easy and cheap fix is to fit an early Mille (White Spring), shock, it fits straight on using the Falco linkages, but the Shrader valve will probably need cutting down slightly, (dremel), to get clearance. If you want to be safe, have it rebuilt and fit a recessed valve. I got one, hardly used, off ebay for £40, fitted it straight on to try, and it made an great improvement, but not as many around now, (probably all fitted to Falcos!).
Good points are 4 way adjustment - Preload, Compression, Rebound and Ride height. The later (Yellow Spring), Mille shocks can also be fitted but you need the Mille linkages as well, (don't come easy second hand, expensive new).
Failing that if you have the money, it's up to you, Ohlins, Maxton, whatever.
Hope you enjoy the bike, sometimes takes a while to get used to a big twin, but you'll love all that grunt. Instant power any time.
Good luck with it.
