Adjustable lock stops
Now that I have my bars on top of my yokes I need a set of adjustable lock stops. AP are out of stock - can anyone help?
Re: Adjustable lock stops
It shouldn't be that difficult to make a set yourself (or get a set made up). It's just a circular slug of aluminium (about 10-15mm deep and 25mm in diameter) with an 8mm hole drilled off centre. Just use the standard Falco lock stops as an example and drill the hole off centre.
Aye, looks like I will have to get some made up.
Sorted. I figured I needed about 4mm on each side, so I took the original lock stop and drilled and tapped it M6, then fitted (and Loctited) a shortened M6 bolt. Works perfectly, and easily reversible.
