carbon fibre fuel tank
Posted: Wed Dec 30, 2020 1:15 pm
by scorpio24v
I'm trying to future proof the Falco from the dreaded ethanol. I've been looking the carbon fibre fuel tank threads and this seems to be the, expensive, way to ensure many more years of Falco riding. Has anyone here used/is using one and if so is an easy fit with no issues? I understand they don't have breathers of drain tubes but that seems to be a non-problem. I'll leave it varnished but unpainted with just the 'Aprillia' decals in bronze (the bike is the bronze/black one).
Happy Christmas.
Vince.
Re: carbon fibre fuel tank
Posted: Wed Dec 30, 2020 5:03 pm
I have one but (to my shame) have not fitted it yet. I know - it's very slack on my part. A number of forum members have the CF tank and all reports I've heard have been favourable. Some (like D-Rider) don't post here very often, but you should get a response from one of the regulars.
Posted: Fri Jan 01, 2021 5:32 pm
I fitted mine last year. It wasn't a straight fit, needed some fettling, it was longer than stock so the front bracket needed shaving back and the holes elongated plus it was a bit of a faff getting the rear bracket mounted (seemed very slightly too wide). But none of this was major work, just a bit of twiddling. I do know some have had a (minor) issue with the fuel pump fitting, where the base wasn't quite flat (think it was over-spray of lacquer so after a bit of sanding it was sorted). Unfortunately mine leaked from a join at the front, however Richard (the guy who made it) took it back and sorted it, even though it was a couple of years since I bought it and it seems fine now.
Depending on what you buy, it might be fitted with a breather - mine didn't, as I run a Baglux harness and the breather would get in the way. I did the fix on the fuel cap (shaving a bit of a plastic collar back to let it breathe) as I did find if pulled a bit of a vacuum, but have to be careful with that fix as I've found you can leak fuel when lifting the tank, I'm considering running breather lines through the tank like the originals (if I can be bothered) but I probably won't :smt003
Have you got a source already for one?
Posted: Sun Jan 03, 2021 2:16 pm
by scorpio24v
Thanks for the reply. Yeah I contacted Richard after reading the original thread. He's still making them to order so I might pull the trigger. I don't think the breather mod is an issue if it only leaks when the tank is lifted...I don't make a habit of lifting mine. I only use the super unleaded from Esso and BP so I've no problems with the original tank...yet! I'm still thinking as £1300 for a tank on a £2.5 K bike represents a large slice, especially as it needs 'fettling'.
Cheers,
vince.
Posted: Mon Jan 04, 2021 9:08 pm
Depends on your perspective - 1/2 hour with the drill and a grinder was about the time required for the front bracket, couple of hours all-in to swap all the components over from old tank to new (inc the refurb stuff below) from old tank fitted to new tank fitted.
Whether the inserts on the front of the tank could be set in 5mm further back I don't know, but that might be all that's required (or might just be on mine - not sure if others had similar issues with the front). Any other time spent is more refurb work on the fuel pump - replacing the filter, changing any hoses etc - not essential, just something that is worth-while doing while it's all stripped.
But yes, it is a significant wedge - my old tank will go back on if I ever sell the Falco, and I'll sell this separately to recoup some of the costs.
Posted: Thu Jan 07, 2021 10:38 am
by Viking
What Firestarter said.
Mine was a right pain to fit - I had to elongate all the holes in all the brackets. I think it's caused a small crack at the front mount point due to thermal expansion in the Oz sun - which I'd like to get fixed because the garage tends to smell badly of petrol if I leave too much in the tank. :-(
@Firestarter - what do you need to do to the filler cap? Mine needs that as well as it doesn't breath very well.
Cheers,
V
Posted: Thu Jan 07, 2021 2:12 pm
I'll try and get a photo later - it was something Richard tested and posted in the post about the tanks (which I can't find in the forum at the moment...), on the underside of the filler cap is a rubber plug, which sits into a plastic stub when the cap is closed. By shaving down the plastic stub, it provides a breathing route from the outside world. It definitely works, as I don't pull a vacuum any more (at least not enough to tell), but I'm not sure if that's where I now get a leak from when lifting the tank (or whether it is from around the filler cap assembly itself).
I guess could also remove the rubber plug as a check, rather than cutting the stub?
My leak was similar to yours maybe (only leaked when the tank was full), Richard sent me some resin which worked for a short period but ended up taking it back to fix it (possibly vacuum related?). I've also re-fitted one of the threaded inserts for the fuel pump using some JB Weld - you could maybe find the spec of the resin or try flowing some JB Weld around the front of the tank to seal the leak?
Posted: Thu Jan 07, 2021 2:20 pm
Posted: Fri Jan 08, 2021 6:12 am
by Viking
Thanks FireStarter, much appreciated.
I will have a look at the plastic filler insert thing, after seeing if the shops here have anything like JB Weld... (I might as well fix 2 things at the same time, rather than taking everything apart twice.)
Have a great weekend, everyone!
Posted: Fri Jan 08, 2021 8:33 am
Make sure you dry the tank out - you might need to flush it with a bit of acetone to get rid of any residue that may prevent any resin from binding
Posted: Mon Jan 11, 2021 4:27 pm
by scorpio24v
Thanks for the replys. it seems that the CF tank has a few fitting problems that for over a grand I'm not prepared to accept. As my tank only gets a diet of the BP and Esso good stuff it hasn't swollen much, if at all, so I'll stick with the original. glad I found out about the issues before pulling and expensive trigger.
Best wishes,
Vince.
Posted: Sun Jan 17, 2021 3:32 am
by Viking
But.... But... The BLING factor of a CF tank!!!! :smt001 :smt002 :smt003
