Separating gear lever from footrest
Before I get the (rubber) hammer out, should the gear lever just slide off the pivot? The gear lever on mine rotates fine but won't slide off.
Re: Separating gear lever from footrest
It just knocks out, as it happens.
- Falcopops
Well if you're knocking one out....
Fnarr. Always worth checking these things - the pivot was very dry, there was an incorrect washer in place of the Belleville washer and the wee ball part of the ball joint was loose. Slapped wrist needed I think.
