Bling
Bling
Hi, while my Falco's in bits getting some attention, does anyone know if there are any blingy chain adjusters available for the Falco swing arm ?
Re: Bling
I swapped out the bolts and lock nuts for stainless but beware the RHS adjuster bolt is shorter than the LHS by about 15 or 20mm, this is because of the caliper mounting stuff on the RHS.
I also swapped both axle nuts for titanium, got them from Jaybeebikerbits
