Falco lock stops
Three Dawg
Falco lock stops
#1 Post by Three Dawg » Tue Jan 21, 2020 1:28 pm
Wheeling the bike out of the garage today I noticed that the lock is a bit more than it should be - the starter button touches the tank easily for example - is this normal for the Falco, doesn't look to be damaged down there. Solution? Larger diameter stops on the yokes?
Re: Falco lock stops
#2 Post by mangocrazy » Tue Jan 21, 2020 4:34 pm
I'd be surprised if something like that happened 'overnight'. You've made no changes to the bars in the interim? From memory the lock stops are adjustable - perhaps one or t'other has vibrated loose?
Three Dawg
#3 Post by Three Dawg » Tue Jan 21, 2020 5:54 pm
No not overnight, probably never pushed it around at full lock or never noticed. Bars are standard and I think fixed into position under the yoke. It does look as though the lock stops on the yoke can be removed and may be eccentrically mounted therefore adjustable, but I was surprised at the fact that the switchgear touched the tank, that shouldn't happen really even if the lock stops are adjustable.
Mind you, I've had a few Italian bikes and they do have their quirks...
#4 Post by mangocrazy » Tue Jan 21, 2020 10:36 pm
I seem to remember that even as new, clearance between the switchgear and the tank on full lock was pretty sketchy. Like you say, Italian quirks...
Falco Frank
#5 Post by Falco Frank » Fri Jan 24, 2020 8:43 am
Rob is selling his own custom sets - through FB initially - good guy to deal with.
https://www.facebook.com/marketplace/it ... ct_details
#6 Post by mangocrazy » Fri Jan 24, 2020 9:53 am
Nice one! I'd seen those advertised and thought what a good idea they were, but then lost the link (as you do with FB). I can see me investing in a set of those.
Falco Frank
#7 Post by Falco Frank » Fri Jan 24, 2020 4:04 pm
No worries - SAVE button is dead handy in FB marketplace - cant be a limit cos I have LOADS saved....
Three Dawg
#8 Post by Three Dawg » Sat Jan 25, 2020 9:42 am
Hmm, clicked on the link and it says sold out.
