Headlight coating??
Posted: Thu Oct 11, 2018 8:59 pm
by Pan
I’ve bought a used uk headlight and it’s been delivered today. It’s in good condition but on the top right hand side a clear coating appears to be peeling, do the have a factory clear coat of some description maybe for UV protection?
Mark
Posted: Fri Oct 12, 2018 10:02 pm
by spiderwheels
Yes there is a coating that may peel a bit given the age. It's probably for scratch protection.
Posted: Sat Oct 13, 2018 10:01 am
by Pan
Cheers. I’m going to remove the rest of it and I could always pus a clear film over it if necessary 👍
Mark
Posted: Sat Oct 13, 2018 12:50 pm
by Gio
You could of course get a stand off cover for it, better protection when a rock hits it.
Posted: Wed Nov 21, 2018 8:57 pm
by Shetland Woody
Mine peeled also, I have a non uk headlight, I had to put some tape over the headlight to make the dipped beam flat rather than kicking up to the wrong side for the mot. When I pulled the tape off after it took some coating off with it. I ended up blasting it with the pressure washer and the rest came off.
