#1
by fatboy » Tue Jun 21, 2016 4:58 pm
Has anyone seen these in stainless or even hard anodised ally ?
Mine are a bit rusty and worn, new rearsets are not the current budget and I dont mind the stock set up apart from the rust and wear.
And I love stainless and shiney
#2
by mangocrazy » Tue Jun 21, 2016 6:41 pm
I'm not aware of any blingtastic aftermarket replacements, I'm afraid. I agree, stainless equivalents would be very nice, both from a corrosion resistance and bling standpoint. The problem would arise in getting the ball joint thingies in stainless, I think, especially as one is LH thread. I've actually tried dismantling those pieces and getting them plated, but disassembly is a pig and reassembly is downright impossible. Well, it was for me...
Strangely the ball joint parts are not silly expensive if your originals are worn too much.
Falco Frank
#3
by Falco Frank » Wed Jun 22, 2016 8:51 am
Oddly, Im awaiting a stainless steel link rod being made by a small business near me.
I got tired of looking at my rusty rod!!!
#4
by fatboy » Wed Jun 22, 2016 4:43 pm
Thanks, new stock parts it will have to be then
#5
by MartDude » Wed Jun 22, 2016 6:17 pm
I take it you're referring to the ball and socket gubbinses? I seem to recall having seen some SS ones on Ebay, from a German supplier, a few years ago.
- Wear the Fox Hat
#6
by randomsquid » Wed Jun 22, 2016 8:18 pm
Are they not just DIN standard rose joints? You can have those off the shelf in any material you want.
#7
by fatboy » Thu Jun 23, 2016 6:12 pm
Not sure they are rose joints from what I understand a rose joint to be.
Could be wrong, often am wrong in my limited knowledge
- Wear the Fox Hat
#8
by randomsquid » Fri Jun 24, 2016 4:45 pm
fatboy wrote:Not sure they are rose joints from what I understand a rose joint to be.
I could well be wrong, It's been a while since I looked at the standard set-up
This sort of thing?
http://www.wdsltd.co.uk/product/3814/sw ... 8-wds-852/
#9
by fatboy » Fri Jun 24, 2016 6:13 pm
Ha, thanks for the link,it provided the info I needed and now I know what to look for, they are actually called angle joints, now to measure up what I need.
- Wear the Fox Hat
#10
by randomsquid » Sun Jun 26, 2016 7:27 pm
fatboy wrote:Ha, thanks for the link,it provided the info I needed and now I know what to look for, they are actually called angle joints, now to measure up what I need.
No probs, I thought some of the bits looked sort of familiar.
#11
by fatboy » Mon Jun 27, 2016 5:20 pm
I will take off the linkage and measure up and compare, if the angle joints are similar enough to work then I will buy some and see how it works out.
It is the same price for 1 to 10 pieces
#12
by fatboy » Mon Jun 27, 2016 5:47 pm
Bollocks
The linkage rod has just sheared in the gearbox end of the fucking rust rotten jobbie.
Plan A it is then, new rust prone mildsteel waste of money parts
