RSV R forks and yokes
Sorry if this old boring news to you encyclopedia heads but I'm watching a set of 99/2000 ones, are these good for my 2001 falc?
Yep, you need forks and yokes as the ohlins are different diameters to the showa/marzocchi forks.
The other thing you need is different bolts to attach the callipers. The carriers on the marzocchi/showa forks use flanged bolts that sit proud but the ones on the ohlins forks are recessed.
The other thing you need to do is to shim the Falco clipons to fit the forks (unless you are fitting the lower clipons from the Mille R)
They certainly work on the Falco and improve it a bit but if you are hoping for the sort of improvement you get from fitting the ohlins shock, you will be a bit disappointed - that said, they are an improvement.
Should you ever decide you want to fit the yokes from the RSVR Factory (Gen II), you will need to fit them as a set and not mix top yoke from a Gen I with a bottom yoke from a Gen II or vice versa. Both work but have different offsets.
Yep - a Head v Heart thingy.fatboy wrote:Thanks for the info D-R.
May make more sense to re vamp the falc ones
I'm glad I've got my Ohlins and as a side benefit, they are a sort of investment as if you ever want to sell them you'll probably get your money back (unless you pay above the odds in the first place).
However if the cash is needed for other things then the other things are probably the better choice
.... by reading info on the forumfatboy wrote:How can you easily tell which forks you have?
https://www.ridersite.com/viewtopic.ph ... cchi+showa
