Battery recharging
Posted: Tue Sep 15, 2015 2:26 pm
by Foxstein
I always find it a pain to undo the two allen bolts on the riders seat to get to the battery.
I was thinking of running two wires from the battery terminals under the passenger seat so I could just attach charger to them. Would I need a certain thickness of wire and are there any pitfalls to this, apart from the obvious shorting. Was thinking of using thick wire with end caps which could be removed for charging.
Good or bad idea?
Posted: Tue Sep 15, 2015 3:17 pm
by HisNibbs
An Optimate or similar often comes with a wiring set. Wires aren't particularly thick as they tend to trickle charge.
Posted: Tue Sep 15, 2015 10:53 pm
by Dalemac
Yeah, optimate, permanently connect the battery then connector under the pillion seat/pod.
Pop the pillion seat/pod off connect the optimate, turn on, job jobbed :)
Posted: Wed Sep 16, 2015 10:35 am
by Tonyunn
This is one fitted, my charger.
You can see it is neat, on the frame along from the brake reservoir.
Posted: Wed Sep 16, 2015 12:08 pm
by wayno
Mine is like that, but hangs down from where I keep tripping over the charging lead :)
Posted: Wed Sep 16, 2015 6:35 pm
Mine is hooked up to Oxford solar charger, comes with 3 connection options.,
Croc clips, fag lighter plug in or permanently fixed ring connection to terminals.
I'm using the latter, plugs into jack plug which is long enough to run out along rear subframe.
My seat is no longer bolted down, as I have to force the seat lugs under the tail unit I guessed it ain't gonna fall off anytime soon, I have some of those neat qr pins which need only r clips but I never fitted the r clips, see above !
Posted: Wed Sep 16, 2015 9:32 pm
by randomsquid
I've got an optimate lead and a solar charger lead on mine both live under the hump.
Posted: Wed Sep 16, 2015 10:01 pm
by flatlander
And if ever a man was going to know about batterie powered toys ...
