m8 1.25 brake caliper bolt countersunk
#1 Post by flatlander » Thu May 07, 2015 4:28 pm
  • its actually to fiit tg rear disk anyone know what length they should be ?
#2 Post by fatboy » Thu May 07, 2015 7:18 pm
I guess you are talking falco here ?
Mine are not c/sunk but proud, overall 20mm.
The caliper mount bracket is 10mm thick so you would need 7 or 8 mm thread length.
Just been out and measured it for you !
Thats a 2001 model so later may differ
#3 Post by mangocrazy » Thu May 07, 2015 9:39 pm
As far as I'm aware front and rear disc bolts are exactly the same. And not countersunk, but flanged.
#4 Post by flatlander » Thu May 07, 2015 11:15 pm
Sorry should have said its to fit an after market wavy disc
Midnight Rider
#5 Post by Dalemac » Fri May 08, 2015 1:16 am
The brake caliper mounting bolts are the same front to rear and are m10x1.25x35mm (excluding the hex flange).
The disk itself is irrelevant to the mounting of the calipers...
#6 Post by fatboy » Fri May 08, 2015 6:58 pm
If you had said DISC mounting bolt I would not have gone and measured the CALIPER mounting bolt.
So when I say I owe you a virtual beer, what I mean is you owe me a beer
#7 Post by flatlander » Fri May 08, 2015 7:35 pm
Look at it this way I could have lied or just edited the post :)
It was something the guy who did the tyres said
Basically you want to get some of these or it won't fit and true to form I wrote half of what he said on a fag packet and now can't find said fag packet :)
