lower fairing
Posted: Thu Apr 16, 2015 5:22 pm
by mrapriliafalco
Could anyone please explain how this fairing bolts on at the rear end,the holes in the fairing don't line up with anything.The only bolt I can see near one side is a engine mounting bolt,and the other the side stand bolts
Has anyone got any pics as I aint got a clue
Cheers lads
Posted: Thu Apr 16, 2015 5:28 pm
I assume you mean something like the skidmarx one?
If so you should have received two metal brackets that fit to the rear most of the side stand bracket, and iirc on of the case covers on the off side
Posted: Thu Apr 16, 2015 5:39 pm
by mrapriliafalco
Yes mate,but i bought it of ebay and came with bugger all
Posted: Thu Apr 16, 2015 6:12 pm
mrapriliafalco wrote:Yes mate,but i bought it of ebay and came with bugger all
Ring skidmarx.
They sell the fitting kit separate
Posted: Thu Apr 16, 2015 6:21 pm
by mrapriliafalco
Thanks pal,will do
Posted: Thu Apr 16, 2015 8:25 pm
by GregD-UK
Ask for the falco destructions as well
Posted: Fri Apr 17, 2015 7:13 am
Yep, there's a bracket for each side - one drops off the bottom of the engine (RHS), the other from the sidestand bracket
Try and loose-fit everything first, as inevitably it won't all line up properly. Because I've got a GSXR sidestand, I had to get busy with the dremel and cut a portion away as the GSXR stand is angled further forward
Posted: Fri Apr 17, 2015 9:11 am
Firestarter wrote:Yep, there's a bracket for each side -............ the other from the sidestand bracket
All-right, all-right .... no need to rub it in ......
Always better to use a paddock stand than rely on the sidestand when fitting these - I know that now ......
