Changing clutch lever
Posted: Wed Jan 21, 2015 1:59 pm
by mrapriliafalco
Can anyone explain why I cannot get the pin to unscrew,I dont wanna try and force it,the brake one popped out !!!
Posted: Wed Jan 21, 2015 4:16 pm
If you look on the underside of the brass barrell, you'll see a little grub screw which is holding the pin in place - undo that first, then the pin should unscrew (and the barrell can drop out). Simples! (Assuming you can get the grub screw without turning the head...)
I'll try and take a pic tonight if I remember
Posted: Wed Jan 21, 2015 6:50 pm
by MartDude
That grub screw is secured with threadlock, and it's a right little sod to get out without snapping the necessarily tiny allen key. Heating it before attempting to undo it is essential - I used a turboflame lighter for a couple of minutes - that was enough to soften the threadlock.
Posted: Thu Jan 22, 2015 8:46 am
by wayno
Took me ages before I noticed that grub screw the first time, I was cursing something rotten
Posted: Fri Jan 23, 2015 1:54 pm
by mrapriliafalco
Why an earth did they bother,didnt with the brake lever,things are impossible to get hold of also
Posted: Fri Jan 23, 2015 8:18 pm
Did you get it sussed? Forgot about the photo, can sort one tonight if you need
Posted: Sun Jan 25, 2015 6:44 pm
by mrapriliafalco
Yes Thank you,its now sorted!! Had to heat the bugger.
Bloody Daft if you ask me
clutch...
Posted: Mon Jan 26, 2015 11:37 pm
by GregD-UK
I took mine out and turned the pin holder to the ickle allen bolt is on the top, so easier to get at in the future! Glad you got it sorted...
