Why can I still only see my elbows?
Some time ago I bought a pair of mirrors with the longer stalks but no matter how I try I still can't see much further than my elbows. Does anybody know if these can be spaced out further please? :(
- flatlander
You have a wingspan like an albatross??
Don't worry a sensible answer will be along shortly :)
Don't see why they would need spacing though kind of defeats the object ? But then I can see past my stubby arms with the standard ones
hi graham
are you certain that you did get the extended mirrors?
reason why i ask is i bought a replacement, the seller swore blind they were the longer ones - nope..... just double check!
http://www.ebay.co.uk/itm/APRILIA-RS50- ... 2c7e6f6eaa
I would be tempted to ring them and ask.
These look like the right ones, but when I rang and checked they were not listed correctly with the pictures.
The RS 125 is the only one that I know of with the long arms?
But as you see in the description it lists more than one bike , which if you looked at this when buying may be the problem.
Give them a ring, they will know what you are talking about. They take card payment over the phone
Hi Pete & Blinkey these are the ones I bought -
http://www.ebay.co.uk/itm/APRILIA-RS125 ... 2a4449dcc3
Which it states are 25mm longer?
It appears to be more that I can't tilt them up far enough due to the button head mirror mounting bolt at the front. I don't have particularly long arms but I'm quite long in the back compared to my short little legs :)
As blinkey says, give them a ring and make sure you have got what was advertised, I have the RS 125 mirrors and compared to standard, you can see loads.
No more outward/upward adjustment left?
Sorry but I'm not going out with a torch and tape measure now, a day working in minus temps, the fire is roaring and I'm having a beer,will not have time to measure/compare mirror arm length till Sunday
That listing is for the correct mirror you want.gramey wrote:Hi Pete & Blinkey these are the ones I bought -
But like I said there was a difference with the listing to the pictures to when I rang.
I will offer a standard mirror up to a long arm one and take a picture and post the differences up tomorrow
- randomsquid
- Wear the Fox Hat
There's about an inch difference to the outside edge.
I'm a wide shouldered fat bastard.
If you get the right ones the difference is night and day.
I've got one on the standard fitting kit and one with the aftermarket bits that came with the mirrors. Slight difference with the OE part being a bit better but the mirrors should be plenty usable with either.
