200 tyre
Posted: Sun Jun 01, 2014 7:44 am
by big alan
will a 200 tyre fit the rim . swingarm ?
cheerss
Posted: Sun Jun 01, 2014 10:46 am
Very doubtful. I have a 190/55 on mine and there's clearance for a cable tie but no more. A 200 would almost certainly foul the chain and chain guard, and possibly the swingarm.
It would almost certainly cock the handling up and could actually be quite unpleasant to ride. You'd also find that the profile would be wrong, and you'd probably never use all of the tyre width, due to it being distorted.
I'd go for a 190/55 every time. Works a treat.
Posted: Sun Jun 01, 2014 8:58 pm
by HisNibbs
Pushing it to the max with a 190/55 I think.
Posted: Mon Jun 02, 2014 11:26 am
by zoidberg
mangocrazy wrote:Very doubtful. I have a 190/55 on mine and there's clearance for a cable tie but no more. A 200 would almost certainly foul the chain and chain guard, and possibly the swingarm.
Care to elaborate on the benefits?
Posted: Mon Jun 02, 2014 12:54 pm
by HisNibbs
Benefits over the 180/55?
With the 180 and 190/50 you get off the edge of the rear tread at modest lean angles so its more of a confidence thing when well cranked over as with the 190/55 , you are bringing more tread into play as you lean on it, rather than less.
180 probably makes the bike a bit mote agile in the low spead corners.
So it's a bit of a trade off between 180 and 190/55 with I the 190/50 I think you get the worst of both.
Posted: Mon Jun 02, 2014 6:58 pm
I'd agree with Keith. A 190/50 is the worst of all options. Actually, bearing in mind the original question, a 200 section is the worst of all options; a 190/50 is second worst.
As Keith says, a 180/55 gives a flatter profile, whereas a 190/55 (by comparison) has a 'pointier' profile (but not excessively so). The 190/55 should put more rubber on the road at 'sporting' angles of lean. I've not found that it slows the steering down at all.
Posted: Fri Jun 06, 2014 6:14 pm
by zoidberg
ta. will bare that in mind when it comes to rubber replacement.
