The Diode Mod is Dead .....
Posted: Wed May 28, 2014 10:42 pm
The Diode Mod is Dead ..... Long Live the Diode Mod.
I've been wanting to try out an idea of mine for a while now .... just been a case of gathering all the bits together and finding the time ..... but it's done and it works.
It's basically an improved (IMHO) version of the diode mod that is needed when fitting LED indicators. This version does not require any modification of the wiring harness (though there is still modification required that is no less of a pain)
It does however give an additional benefit that is equally useful whether you have LED indicators fitted or "traditional" incandescent bulbs.
While I get on with another useful mod I've been thinking about, I suppose I'd better let you start guessing what the mysterious "additional benefit" of this "new diode mod" might be ......
You may have some time to guess as it'll probably take a while to perfect the other mod
Posted: Thu May 29, 2014 12:57 pm
by Dalemac
Have you mounted an led tv at each indicator point, meaning more power is needed (hence no diode mod).
Added benefit being people can't complain they don't know which way you are going?
Perfection time being mounting them in a way so the bike can actually lean and go round corners?
Posted: Thu May 29, 2014 2:14 pm
Good try Dale ... but it is much more simple than that .... and I've not been anywhere near that imaginative !
:smt005
Posted: Thu May 29, 2014 6:48 pm
Will the additional benefit be that it will make me irrestistable to both Emma Watson and Shakira ?
Posted: Thu May 29, 2014 8:01 pm
fatboy wrote:Will the additional benefit be that it will make me irrestistable to both Emma Watson and Shakira ?
Why do you think I came up with this idea .... and am not letting on to everybody else ..... :smt002
Posted: Fri May 30, 2014 8:04 am
by Dalemac
D-Rider wrote:Good try Dale ... but it is much more simple than that .... and I've not been anywhere near that imaginative !
:smt005
Slow day at work :D
Posted: Fri May 30, 2014 9:22 am
:smt005
Slow day at work :D
I'm on holiday (with loads of things that need doing outside ...... guess that's the cause of all this crap weather .....)
Posted: Fri May 30, 2014 10:06 am
by Dalemac
:smt005
Slow day at work :D
I meant that I was having a slow day at work :D
Ahh, holiday. Still got 5 weeks to take this financial year :D
