Gorilla vs Falco
Posted: Sat May 24, 2014 7:40 am
by KitchenSync
Brittany-Ferries gorilla with ratchet straps VS Aprilia Falco
Sadly Falco loses - it must take a lot to bend 15mm of steel rod but they did it.
Eventually the weld failed - after I had gone up to the lounge but before we'd left Le Havre.
Stupid thing is I watched him strap it down but didn't see the suspension compressing as he wound it down - thought it seemed odd but being British said nothing as there were three other gorillas watching him do it.
So new stand needed urgently, plus new cans (one of them has a nice dent in it) plus the left clip-on is bent - all courtesy of Brittany-Ferries.
Pics to follow and a viscous social media campaign if they try "the stand was clearly at fault"
Grrrrr
Posted: Sat May 24, 2014 8:38 am
i believe that something similar has happened before - and that case ended in court - or close to it....
was it a standard side stand?
what exhaust is it?
present them with the bill....
Posted: Sat May 24, 2014 9:07 am
by Smilinjack
When I sailed to Santander in 2011 they strapped the bike so hard it went forward off the stand-as I realised when they released the strap and my VFR rolled forward into a water cistern. I managed to catch it but the front quarter fairing was damaged. And it didn't end there. Couldn't restart the bike in Jaca, due to the underseat alarm sensor being broken and luckily waiting in the battery tray for me to repair it. Good luck mate. :smt001
Posted: Sat May 24, 2014 9:48 am
All of these incidents demonstrate that their system for securing bikes isn't fit for purpose.
No sidestand is designed to have that sort of load on it so strapping it down like that is not appropriate.
They need to install a proper clamping system that doesn't load parts of bikes that are not meant to be overloaded.
Maybe there needs to be some campaign to approach the ferry companies to suggest that they protect themselves from claims for this damage by installing a proper fixing system - pointing out that if they do so and advertise it, then they will benefit by a lot more trade coming their way.
Posted: Sat May 24, 2014 10:19 am
by jonnie_r
Hence why I won't be ferrying to Spain, but taking the Eurotunnel and bashing down through France and across the Pyrenees.
Posted: Sat May 24, 2014 12:31 pm
by KitchenSync
I 'm not sure if it's an OE stand - I imagine not as it's never been close to blowing over. Maybe someone can tell me when I put the pics up.
They are Scorpion S/S cans.
It would help if they put the ratchet on the opposite side of the stand that way the pressure is absorbed by the suspension rather than focused on the stand but yes - they should have a better system. My seat is also knackered from 7 crossings. Imagine if this had been a fancy BMW - they'd be liable for £1000s.
Posted: Sat May 24, 2014 12:35 pm
by KitchenSync
When the RAC had to recover me once (grit in one of the camchain tensioners) and put the bike on the flatbed they used two straps through the frame tubes.
Posted: Sat May 24, 2014 12:47 pm
by flatlander
They used to be meant to use airbags but tgemomen never had enough we always used to put gloves and extra bits of clothing under the ratchet strap to stop it being fully compressed and to protect the paint
I say used to because now and for quite a while I have used the tunnel and its great
The Pics
Posted: Sat May 24, 2014 2:06 pm
by KitchenSync
So what stand is this?
Re: The Pics
Posted: Sat May 24, 2014 2:48 pm
KitchenSync wrote:So what stand is this?
..... a broken one !
(looks as though it was a standard one)
Posted: Sat May 24, 2014 5:04 pm
by Smilinjack
Portsmouth to St Malo on my ZZR1200 last year :smt012
Posted: Sat May 24, 2014 5:59 pm
by Dalemac
that's definitely a standard falco stand.
I'd have thought something like this would be much better than ratchet strapping down...
https://www.youtube.com/watch?v=p_1NkHRn4rA
Posted: Sat May 24, 2014 6:27 pm
by bigun
Strange, that definitely looks standard yet when I had it, I fitted a GSX-R stand ( think it was gixxer, may have been blade). Why anyone would revert to standard is beyond me! Hope you get it sorted.
Posted: Sat May 24, 2014 7:30 pm
by KitchenSync
Dalemac wrote:that's definitely a standard falco stand.
Clearly doesn't work - he keeps having to buy another bike!
Posted: Sat May 24, 2014 7:46 pm
by KitchenSync
Just nabbed a Firestorm stand on fleabay for £30....
Meanwhile that RSV engine is going in tomorrow... *gulp*
and before the stand arrives it's off to CMC just up the road from me to get a quote for:
**** edited that out - they may be watching *****
