Changing rear Brake pads
Posted: Tue Apr 01, 2014 10:29 am
by mrapriliafalco
Im really not tec minded so hope I can be pointed in the right direction
Need to change the rear pads,apart from the obvious pins to take the pads out, and pushing pistons back in,do you have any tips to help out a novice
Posted: Tue Apr 01, 2014 11:14 am
by zoidberg
Have a competent friend help you.
Posted: Tue Apr 01, 2014 6:37 pm
I will take pics and post them up. Be patient
Posted: Tue Apr 01, 2014 7:05 pm
A mate helping is a good idea. Wire brush all the crap off the retaining pins, give em a squirt of WD40 type stuff. The E clips on the end of the pins can ping off into oblivion when you lever them off,a mate there with a rag making a safety net is agood idea.
Clean all the shit off the pins before re fitting use a bit of copper grease on the pins, keep all grease well away from new pads.
DONT try this w/out the help of some one who knows, its not complex,just fiddly
Posted: Tue Apr 01, 2014 8:06 pm
by HisNibbs
Also keep wd40 well away from the pads and disc too.
